Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 01-15-2013, 06:44 PM   #1
pitched mud job over cement slab - advice?
Bidding a job at an animal hospital. They have a 5'x5' bath area enclosed with a 5' high wall, a grated 24" door and a 5" curb. Drain is in the corner opposite entry. There is peeling epoxy paint over a very poorly pitched cement slab (many dips and bumps). My plan is to raise the drain up 1 1/2" (cement mix would be 1 1/4" at thinnest, 2 3/4 at thickest), remove the paint, go over the slab with thinset and a notched trowel (extra bonding?) then do a properly pitched mud job with sand/portland cement mix, put a kerdi waterproof sheet over it and tile + grout. Anyone have any better ideas, suggestions? Sorry no pic
Frattman is offline   Reply With Quote
Old 01-15-2013, 08:27 PM   #2
Tileguy
JazMan's Avatar
The plan sounds almost perfect. What type of drain will you use? How are you gonna seal between the membrane and the drain? You need to use a Kerdi Drain for the Kerdi Membrane to work. They make an adapter to go from old drain to new Kerdi Drain. But I think it'll work only if the old drain is a two-piece shower drain. http://m.youtube.com/watch?feature=plpp&v=LOxh5uT8xqs Otherwise you could go with a liquid membrane like Hydroban or Redgard. They have their own method which you should be able to find at their sites.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
The Following User Says Thank You to JazMan For This Useful Post:
Frattman (01-15-2013)
Old 01-15-2013, 09:33 PM   #3
existing drain is mortared in place, getting the plumber to raise it up and installing the kerdi drain - thanks jazz.
Old 01-15-2013, 09:55 PM   #4
Tileguy
JazMan's Avatar
Great. Sounds like it's a regular floor drain otherwise a plumber wouldn't be necessary. I like the Kerdi method if you want it to be waterproof. Best way to go. Not the cheapest, but...........
Jaz
Better - gravel or paver base for cement slab ? timcsi Building & Construction 1 08-19-2011 10:26 PM
XPS foam board between basement slab and cement board for ceramic tiles jpsmith Flooring 4 02-10-2009 09:17 PM
Sealing/painting cement slab for humidity? mcu Flooring 2 04-24-2008 10:53 PM
Radiant Heating on Cement Slab can'tdecide Flooring 2 08-21-2007 01:59 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
