-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   pitched mud job over cement slab - advice? (http://www.diychatroom.com/f84/pitched-mud-job-over-cement-slab-advice-169233/)
Frattman 01-15-2013 06:44 PM
Bidding a job at an animal hospital. They have a 5'x5' bath area enclosed with a 5' high wall, a grated 24" door and a 5" curb. Drain is in the corner opposite entry. There is peeling epoxy paint over a very poorly pitched cement slab (many dips and bumps). My plan is to raise the drain up 1 1/2" (cement mix would be 1 1/4" at thinnest, 2 3/4 at thickest), remove the paint, go over the slab with thinset and a notched trowel (extra bonding?) then do a properly pitched mud job with sand/portland cement mix, put a kerdi waterproof sheet over it and tile + grout. Anyone have any better ideas, suggestions? Sorry no pic
JazMan 01-15-2013 08:27 PM
The plan sounds almost perfect. What type of drain will you use? How are you gonna seal between the membrane and the drain? You need to use a Kerdi Drain for the Kerdi Membrane to work. They make an adapter to go from old drain to new Kerdi Drain. But I think it'll work only if the old drain is a two-piece shower drain. http://m.youtube.com/watch?feature=plpp&v=LOxh5uT8xqs Otherwise you could go with a liquid membrane like Hydroban or Redgard. They have their own method which you should be able to find at their sites.
Jaz
Frattman 01-15-2013 09:33 PM
existing drain is mortared in place, getting the plumber to raise it up and installing the kerdi drain - thanks jazz.
JazMan 01-15-2013 09:55 PM
Great. Sounds like it's a regular floor drain otherwise a plumber wouldn't be necessary. I like the Kerdi method if you want it to be waterproof. Best way to go. Not the cheapest, but...........
Jaz
