Pattern In Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-07-2009, 01:49 PM   #1
Rewards Points: 26
pattern in floor
I am tiling my kitchen floor with 12x12 tiles and am thinking about doing some kind of pattern in the layout. The kitchen is a square and I'm thinking of if making some sort of design about 2 ft into the layout, either tiles on a diagonal or a different tile. Here is a picture, not the best but hopefully it will get the idea accros. pattern in floor-tile-layout.jpg
The square with no tiles on it is where I would like to do something different in order to break up the square pattern and creat an interesting look instead of a bunch of 12x12 squares. What is the best way to tackle this? I would think to snap some lines and then tile some parts and wait till the next day and do the rest? Or should I do it all in one day? Thinking maybe do the 12 inch tiles the first day and leave the middle line empty and the next day put in the tiles in between the 2 sqaures? Not sure I guess. Thanks for any input with this.
ponch37300 is offline   Reply With Quote
Old 06-08-2009, 04:19 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Lay out the entire room with chalk lines as if there were no feature. Decide what area to leave out in the center then tile around that area.
Next day chnage thye layout inside the feature and go for it. Swap/stagger grout joints systematically when possible.
Old 06-08-2009, 05:55 PM   #3
Rewards Points: 26
Thanks bud! So if I just want to leave one row of tile out all the way around like in my rough drawing and then put a pattern in were I left that row out should I do the outside tiles and inside tiles and the next day do the row of pattern tiles? Make sense? Thanks again.
Old 06-08-2009, 06:31 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That would work!!!
You could turn the tiles inside the border on a diagonal to spice things up a bit.
Old 06-08-2009, 06:46 PM   #5
Rewards Points: 26
Thanks again bud.
Old 06-08-2009, 07:47 PM   #6
the Musigician
DangerMouse's Avatar
you could use 4"x4" tiles in that area for accent too, different colors could spice it up a bit.
diagonal would be a bit of cutting......
DM
Old 06-08-2009, 08:34 PM   #7
Rewards Points: 26
Thanks for the ideas guys. I haven't decided what exactly I'm going to do in that area but wanted to break it up somehow so it wasn't a bunch of squares and just wasn't sure what order the tile should be installed.
Old 06-08-2009, 08:40 PM   #8
the Musigician
maybe use 2 rows of 4"x4" on the outsides and use 1" through the middle!
DM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Installing floating floor over squeaky wood floor- rip it up? (Q3) cee2ski Flooring 1 02-09-2009 06:23 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
Attaching 3/4 Sturdy Floor with PL 400 jamiedolan Flooring 1 09-04-2008 09:15 PM
Molde: Underside of Attic Floor stangboy68 Building & Construction 9 12-06-2007 09:53 AM
