Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 10-30-2010, 07:08 PM   #1
Patio tiling
We have a patio that is poured concrete and would like to make it look a little nicer. It is poured in 4 slabs with exxpansion joints (with wood filler) in between.
We considered porcelain tile, but we understand we cannot cover the expansion joints. Are there additives that would allow us to use porcelain tiles over expansion joints? Would slate tiles have the same problem? We have rather humid conditions, ranging from ~ 20F to 110F.
What other alternatives do we have for a DYI? I have an additional concern that I do not want to raise the patio too much (so rain water won't get in the house), so I cannot use thick pavers. We are open to anything that's pleasant looking and easy to clean.
injvstice is offline   Reply With Quote
Old 10-31-2010, 09:49 PM   #2
Tileguy
JazMan's Avatar
Patio tiling
I'm not aware of any way to successfully tile over the expansion joints in an outdoor installation. But why do you think it's a problem to install tiles on that patio? It's done all the time esp. in fair weather zones.
Hopefully the cuts or cold joints are square so you can utilize them as the grout lines of your starting point. There are specific guidelines, but it can work.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 11-02-2010, 12:14 AM   #3
Patio tiling
I do not think it's a technical issue, I just find it ugly to have a somewhat small (maybe 10x10) patio broken up into three non-equal pieces. The expansion joints are larger than your average grout line, they are about 1-2 inches. I would just like to make the patio look like a contiguous piece.
Maybe I'm misunderstanding what you are suggesting?
Old 11-03-2010, 06:01 PM   #4
Tileguy
Bud Cline's Avatar
Patio tiling
How about a picture of this patio.
Are you sure these joints are 1-2 inches wide?
Tags
patio, paving
Tiling Outdoor Patio Branden Flooring 2 06-23-2010 11:24 PM
Tiling over cement patio Clemey Tiling, ceramics, marble 3 06-13-2010 06:07 PM
Tiling a patio that already has screen enclosure. gggonzalez Flooring 2 05-02-2010 11:25 AM
Tiling Over Aggregate Patio patch Flooring 2 03-18-2010 08:13 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
