Old White Bath Tile Is 11cm. Want To Replace Some. Can't Find 11cm. Help?! - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 09:58 AM   #1
Old white bath tile is 11cm. Want to replace some. Can't find 11cm. Help?!
The old white bath tile is 11 cm
( slightly larger than 4 1/4&quot
I want to replace a few
I can't find it anywhere. And the larger ones from Dal tile are not a perfect color match...
Please help me find this..
We have ugly 1980s style trim and floor pattern we want to cut out and no, redoing the whole room isn't more cost
Effective in this case.
HoneyKayke is offline   Reply With Quote
Old 06-03-2011, 01:08 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 220
Finding older tiles and expecting a match is not realistic. That's why you're supposed to order and keep spares. Even the same batch from years ago would not match the in-service tiles. They do change a little.
Your tile are 4 3/8", about 1/8" larger than most. There were several brands that once made the larger size. You should find Florida Tile brand and see if the white comes close enough. There are many dozens of shades of white possible, and they may only make one.
Jaz
Old 06-03-2011, 01:08 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
As you're discovering, finding a perfect match to a vintage tile is like searching for a needle in a haystack.
You might have to settle for something that would complement it.
Try Googling "vintage tile" if you haven't already. There are places that will manufacture matching tile but they ain't cheap.
Old 06-03-2011, 04:42 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Probably not going to happen.
If you were to find the identical color and the size you need you will be the luckiest person in the world. You should then go to Las Vegas and spend every dollar you have on a single spin of the roulette wheel.
XXX
Old 06-06-2011, 04:23 PM   #5
ccarlisle's Avatar
Metric tiles, eh?...Where are you from?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
How do I find a specfic 18" Slate Tile? mouerlabs Flooring 2 07-15-2009 10:02 AM
bath room tiling question, laying tile around a curve everyman Kitchen & Bath Remodeling 2 02-14-2009 02:21 PM
Tile Bath Tub? mommaroot2004 Remodeling 3 11-28-2006 09:28 PM
