Old Victorian Tile Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-14-2013, 05:31 AM   #1
daveni50's Avatar
Rewards Points: 14
Old victorian tile floor
Upon buying my house I removed an old carpet in the hallway and found this old Victorian tiled floor. It's only partially tiled as the bit under the stairs seems to be concrete. Any suggestions what to do to finish it ? Shelving to cover the concrete? Wooden floor? Concrete paint?
daveni50 is offline   Reply With Quote
Old 08-14-2013, 05:49 AM   #2
daveni50's Avatar
Rewards Points: 14
Originally Posted by daveni50
upon buying my house i removed an old carpet in the hallway and found this old victorian tiled floor. It's only partially tiled as the bit under the stairs seems to be concrete. Any suggestions what to do to finish it ? Shelving to cover the concrete? Wooden floor? Concrete paint?
Old 08-14-2013, 06:38 AM   #3
DIY staff
Rewards Points: 7,174
That's sharp!
Originally there was a wall or cupboard below the stairs----
If you could post a picture from the front door ,down the hall it might be easier to get good suggestions===Mike====
Old 08-14-2013, 06:54 AM   #4
daveni50's Avatar
Rewards Points: 14
Will do mike... I'll look forward to your thoughts
Old 08-14-2013, 07:18 AM   #5
DIY staff
We have several old time stair and trim pros here---along with a bunch of antique house lovers---Mike----
Old 08-14-2013, 10:07 AM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Cool floor!
Can't tell from the pic, but is the concrete lower than the tile. If so, I'd do tile.
It is extremely unlikely you will find the identical tile, but you may find something that will coordinate with what is there. If you look for tile, don't forget to consider the thickness of the tile.
What do you plan to do with that area? A built-in of some sort, or piece of furniture would be my first choice. If it is near an exterior door, a bench to sit and take of shoes might be an option.
Old 08-14-2013, 11:02 AM   #7
Too Short? Cut it Again!
Cool floor and it looks to be in reasonable shape. Somebody probably disliked the color. Anxious to see the long view from the door.
I would build yourself some nice storage drawers under the staircase. I will see if I can find some picture ideas.
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 01:07 AM
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 07:49 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 06:58 AM
Removing floor tile glue from a wood floor mrmordun Flooring 2 09-03-2008 10:41 PM
