Newbie! How To Tile Bathroom!!! - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-29-2011, 11:07 AM   #1
Newbie! How to tile Bathroom!!!
I wanna put in a new tub and then tile the walls - not the floor
The hardware store said to remove the drywall where the tub is and then put up cement board, then put tile over that board.
is that it?
digdug is offline   Reply With Quote
Old 11-29-2011, 11:11 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
is that it?
Basically YES!
The studs should be covered with a vapor barrier of plastic before the wallboard is installed, or a liquid waterproofing can be used on the surface of the wallboard eliminating the plastic vapor barrier.
Old 11-29-2011, 11:47 PM   #3
plastic over the studs, cement board and then tile?
I'm a little confused about right/wrong way to tile...I thought you just lay each tile in, use the seperators and keep going...
gonna use a bigger tile...should I go right to the ceiling? Actually that would be prettty dumb...maybe just as high as the shower nozzle
thanks
Old 11-30-2011, 04:49 AM   #4
DIY staff
Rewards Points: 7,174
I suggest that you look at some pictures of tiled showers ---books --magazines and even google images.
Most showers are tiled all the way to the ceiling ---How you do it is a matter of style--
Old 11-30-2011, 11:46 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
is that it?
There's a little bit more to it than that.
I'd suggest checking out Bud's blog.
http://www.diychatroom.com/blogs/con...wer-walls-152/
Old 12-01-2011, 11:47 AM   #6
Great info on this page, but now I AM MORE CONFUSED
I don't know which way to go with so many options.
If cement board sweats and mortar bleeds through then the only thing I have is my vapour barrier acting as my "waterproofing"
Old 12-01-2011, 01:04 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...but now I AM MORE CONFUSED
Can't help with the confusion. You've read the current information, make some decisions. If you have specific questions...ask away. Keep in mind this is a how-to type website not a place to go for therapy sessions.
XXX
Old 12-02-2011, 08:21 PM   #8
I'm gonna poly then cement board then tile
Replacing tile in bathroom floor (2x2 tile) Paul8434 Remodeling 1 09-05-2011 06:06 PM
Failing bathroom tile floor--best options quinten Flooring 3 11-16-2010 06:56 PM
Bathroom Floor Tile Questions BaconK5 Flooring 2 08-19-2010 09:36 AM
7 months pregnant and Nasty Bathroom Tile RaeEllen Remodeling 8 07-14-2008 11:10 AM
Help! Botched bathroom tile job steamed17 Remodeling 13 05-01-2008 09:40 PM
