#1 |
new to glass tile
Done a few reno bathroom jobs of porcelain and ceramic, but never worked with glass.
The better half picked a 3x5 glass "subway" tile to run in a vertical brick pattern for the tub surround...lots and lots of them Anything specific to glass that I should know about as far as modified thinset or grout selection? If i used redguard to seal durock, will it show through the tiles (should i use ditra?) Last edited by redline9k; 02-11-2013 at 10:07 AM. |
#2 |
new to glass tile
I just completed 2 bathtub surrounds, all glass. Use what the tile manufacturer recommends for thinset. The tile I used came with a white backing. If your tile is unbacked, you're supposed to knock down the ridges after spreading the thinset so the grooves don't show through the tile.
The Redgard should not show through the thinset. If your tile requires modified, don't use Kerdi. Kerdi wants unmodified. There are arguments that modified can be used with Kerdi, but I wasn't going to risk it as the tile is too expensive to replace. I waited 3 days to grout... just to give the thinset time to fully dry and let any moisture out. I don't know if it was necessary but did it anyway since glass isn't porous. |
| Display Modes | |
| glass tile over greenboard at bathroom vanity | Testarossa214 | Tiling, ceramics, marble | 0 | 03-05-2012 03:48 PM |
| Glass and metallic mosaic tile | homefixgirl | General Discussion | 9 | 12-23-2010 09:42 PM |
| Install glass tile on wood stud pole (for support beam) | chatelain | Remodeling | 1 | 06-21-2009 11:45 PM |
| Glass Tile Installation | hms2205 | Tiling, ceramics, marble | 2 | 06-20-2009 08:46 PM |
| removing glass 4x4 tile | tilewoes | Building & Construction | 1 | 06-10-2008 10:54 PM |
