Neophyte To Install 2x2 Ceramic Mosaic Wall Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-17-2010, 10:25 AM   #1
Neophyte to install 2x2 ceramic mosaic wall tile
Hi,
I want to continue a tile installation that was stopped sometime ago. I have 2x2 ceramic mosaic white wall tile that I want to install over painted cement backer board on one side and painted green board on the other. The paint was laytex primer. I need to scrape off some old globs left from the first install and then I'm ready to roll. I know I need to use a heavily modified laytex thinset.
Any other suggestions? Do I start at the top with the matted 2x2 and work down, or do I start at the bottom and work up? How do I keep the tile form sliding down the wall before it sets up? I'm trying to align with the original install.
Thanks. Vickie.
Vickie is offline   Reply With Quote
Old 01-17-2010, 02:31 PM   #2
make a straight lone from one side to the other one row up. then fasten a thin board along the line.set tile on top of the board till thin set is dry. remove board then cut tile to bottom.
just tile is offline   Reply With Quote
Old 01-17-2010, 04:40 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Paint, especially latex paint, is a known bond breaker when it comes to tile installations. If this is in a wet area maybe you should back up and rethink this.
XXX
Old 01-17-2010, 05:43 PM   #4
buds right if its a wet area you need to be sure you have no paint between your backer and you thinset. the moisture could release the bond.
Konecto flooring LookoutRanch Flooring 23 03-08-2010 03:32 PM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 11:35 AM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 10:00 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 12:08 PM
