Need A Quik Temporary Fix For A Shower Tile ? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 04:32 AM   #1
Need a quik temporary fix for a shower tile ?
Here is my problem the bottom row of tile in my shower are coming lose grout is cracked and water is leaking behind and ending up downstairs the solution is obvious the shower needs to be gutted and redone but I need a temporary fix for a couple of months until I can get to it any suggestions or any good product to patch this up
ants1929 is offline   Reply With Quote
Old 04-22-2012, 06:09 AM   #2
DIY staff
Rewards Points: 7,174
You are going to need to tape that---
Use aluminum foil duct tape or window flashing tape---or cover the entire inside of the shower with heavy plastic.
It'll look like hell but will keep the water inside the tub.
Old 04-22-2012, 07:49 AM   #3
Can I use a caulk and just seal the tile with it ? Any suggestion on what kind of caulk don't care if it looks bad it will al be ripped down soon !!
Old 04-22-2012, 08:02 AM   #4
DIY staff
Tile and grout (all of it) is not water proof----that is why the wall behind your tiles has rotted away---those 'loose' tiles are only there because of the remaining grout---you have nothing behind them but rotten drywall.
Caulk won't do it---it's to late----cover the walls with plastic or tape until you can add a new waterproof surround---sorry---no quick fix when the wall has reached the point of damaging the room below---Mike---
Old 04-22-2012, 08:13 AM   #5
Ravenworks's Avatar
No you can't,why? because what is the caulk going to adhere to?
"Oh"- Mike hit it
Ravenworks is offline   Reply With Quote
Old 04-22-2012, 08:24 AM   #6
Rewards Points: 2,516
ice and water shield????
hammerlane is offline   Reply With Quote
Old 04-22-2012, 08:45 AM   #7
biggles's Avatar
tape up a heavy plastic skirt 2 tiles up from the tub edging like that ice rubber sheet suggested couple of inches into the tub all the way around......if the sheet rock is powder to the touch it is going to have to be ripped out and what is going on behind the tub as the water runs down...forget about caulking it...
Crack in old shower tile Jeff DIY Flooring 21 01-15-2012 02:11 PM
Tile or fiberglass shower? Proby Tiling, ceramics, marble 18 07-26-2010 04:49 PM
Tile shower pan leaking Daniel048225 Building & Construction 2 10-15-2009 02:18 PM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
Building a tile shower ghostrider20 General DIY Discussions 2 03-01-2007 08:54 PM
