Need Input Please! (Mosaic On Tile) - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-14-2011, 09:20 AM   #1
Need input please! (Mosaic on tile)
I just finished tiling the shower and instead of running a pencil trim or some type of quarter round along the space between where the tub and tile meet I was going to run a 1" mosaic all around. My question is can I use an Armstrong tile adhesive of some sort to glue the mosaic to the tile? Then afterwards grout and seal... Thx in advance for any input!!
tandj1997 is offline   Reply With Quote
Old 04-14-2011, 11:59 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Generally caulking is used between the tub and the tile (as well as any other change of plane).
Do you have a pic?
Old 04-14-2011, 01:14 PM   #3
Rewards Points: 5,336
I don't understand why you would install a 1" tile in that location. As a matter of fact, the other 2 tile situations aren't appropriate.
You might want to tell us what you did to the walls for the tile prep.
What material backer?
What type of tub?
How close to the tub did you install the backer?
A small tile wouldn't have the support at the tub bottom as the substrate is off the tub surface by 1/4-3/8". If you follow the instructions with some tubs, the substrate could be a full inch off the surface.
Use thinset for adhering the tile.
Ron
Old 04-14-2011, 01:38 PM   #4
What type of tub?
Ron
It's not for you to understand. Obviously you haven't seen may bathrooms in your lifetime. And the mosaic will be going on top of the tile not below it.
Why is it that no one on here like's to answer a simple question? All I asked was what kind? And yes I can take constructive criticisim, but your last paragraph wanting to know everything about how and what was used to put the tile on is not needed. That part is done. And it was done right. If I had a question about that part I would have asked don't you think?
Like I said everyone on here goes on a long string. See the question was not what would look good the question was what kind of adhesive to use. CAULK will be applied last. So thanks for that tid bit of info
Old 04-14-2011, 01:41 PM   #5
BTW Ron thinset will not work tile to tile. If you read it right the first time you would see that the mosaic is gonna be placed on top of tile... Not on cement board! Already found the answer I was looking for else where. Thx for the lengthy post
Old 04-14-2011, 07:29 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
hehehe Ron!!! You got in trouble for trying to be thorough. That a$$ eating she gave you is what you get for trying to help answer a stupid question. No good deed goes unpunished my friend.
That's the kinda chit that happens to me around here ever so often.
Okay - moving on. LMAO but moving on!
XXX
Old 04-14-2011, 07:58 PM   #7
DIY staff
Rewards Points: 7,174
Well,Wasn't that special?
Mosaic on TOP of the tile---Ron, you haven't been in many bathrooms,have you ---
Everyone knows about mosaic TOP glue!------Mike-----
Old 04-14-2011, 08:03 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
After reading this thread, now my wife wants to glue an iron skillet to our kitchen wall. What kind of glue would I use to do that?
XXX
Old 04-14-2011, 08:23 PM   #9
It goes to show you, you can't keep all the people happy all the time.
Ron
Old 04-14-2011, 08:26 PM   #10
DIY staff
Bud--standard 'Frying pan and Skillet glue'---It's next to the Mosaic TOP glue at the twilight Zone Home Center.
Old 04-14-2011, 09:25 PM   #11
Rewards Points: 282
Tile to tile? I don't know. Silicone? I wonder what answer the OP found while waiting for an answer here? Maybe she will share when she's done being PO'd at Ron.
Jim F is online now   Reply With Quote
Old 04-15-2011, 08:26 AM   #12
Yeah... It is hard to keep people happy with mindless answers and rants
I heard there were a bunch of HILLBILLIES on this forum. I guess my source was right! BTW the skillet sounds like a good idea... You must live out in the styx somewhere... That's the last of my thoughts on this topic. Toothless hillbillies aren't worth the time! See ya Sallys!
Old 04-15-2011, 08:31 AM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Dirtbag!
XXX
Old 04-15-2011, 05:14 PM   #14
Rewards Points: 282
Enjoy your tile on tile tub and go annoy someone else.
The Following User Says Thank You to Jim F For This Useful Post:
oh'mike (04-16-2011)
Old 04-16-2011, 06:28 AM   #15
DIY staff
[quote=tandj1997;629848]Yeah...
Oh,Damn, I've done been found out!
Mosaic tile for the bath floor sunman Flooring 2 04-13-2011 03:36 PM
Listellos with glass mosaic tile mskiwimango Tiling, ceramics, marble 0 02-12-2011 11:51 AM
glass mosaic tile that already have adhesive rountree18 Kitchen & Bath Remodeling 1 02-03-2011 10:09 PM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 01:35 PM
cutting mosaic tile amakarevic Flooring 6 06-04-2008 04:02 PM
