Need Help With Travertine/Marble Backsplash - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 08:20 PM   #1
Need help with Travertine/Marble backsplash
I had put up a travetine/marble/glass mosaic back splash. Runs under my kitchen cabinets and a large portion up the wall behind the range. Here is a link to the tile I am using www.goldenselect.ca/en/mosaic-wall-tile/
I wanted to keep the travertine open and unfilled with grout. I went and sealed the tile and holes with 511 tile impregnator. I had read to use a putty knife for the grout so I do not fill the holes. I did a test piece and it did not work out with the tile being so small and close together.
What about a grout bag? Would I be able to get such a small bead out of the bag? The space is a little tighter that a 1/8" and am using unsanded grout.
This may sound silly, how about using a larger syringe. Like ones that come epoxy.
drex is offline   Reply With Quote
Old 06-30-2012, 09:36 PM   #2
DIY staff
Rewards Points: 7,174
It can be done---but it will take you many hours---I know,I have done it---
Go to a place that sells cake making supplies--there you will find the tips you need and the pastry bags---
You will destroy a lot of bags--so stock up and be patient---it will take time --Mike---
Old 06-30-2012, 09:38 PM   #3
DIY staff
A refillable caulking gun might be worth the expense--I have never tried one--but I believe that it would make the job easier--
Old 06-30-2012, 09:41 PM   #4
Or get a freezer bag like glad or ziplock (much thicker then a sandwich bag) Make a suitable cut in the corner
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
oh'mike (06-30-2012)
Old 06-30-2012, 09:59 PM   #5
DIY staff
It takes a lot of pressure to squirt out grout---The pastry bags don't last long---Look into a refillable caulking gun--I like that idea--
Old 07-01-2012, 01:28 PM   #6
For anyone in the same situation, I found this on amazon. A little bit over priced for what it is, but will give it a try.
COX Mechanical Advantage Gun
http://www.amazon.com/COX-41006-Poin...e+caulking+gun
Old 07-01-2012, 02:56 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 388
Waste of money. But if you have a brick veneer house........
Jaz
tiling over laminate/formica backsplash doqfleed Tiling, ceramics, marble 4 06-14-2010 11:25 PM
Tiling / backsplash question Mark755 Kitchen & Bath Remodeling 4 02-26-2010 01:01 PM
Backsplash behind all counters? Birdsell5 Remodeling 2 12-19-2009 06:16 AM
Attaching a backsplash to wall/countertop DanBress Carpentry 3 09-10-2008 08:09 PM
Tiling kitchen backsplash deeaa Building & Construction 6 07-17-2008 08:44 PM
