Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 01-05-2013, 03:18 PM   #1
Rav
Need help re-caulking/grouting wall tiles
I'm not sure this is the right forum (since what I have is bathroom wall tile and this forum says "flooring"); if not, please direct me to the right forum.
Please see picture below. The tile on our bathroom wall is probably original to our 1931 house. At least a few decades ago someone re-caulked one area, doing a sloppy job, with the wrong color, and it's cracking. I assume what they used is caulk -- it's "rubbery." The area they caulked is between the last row of flat tile at the bottom of the wall and the "curved" tile (which butts up against the floor tile).
I want to remove all the old caulk and re-caulk (or re-grout?) it. The gap to be done is 1/4 inch wide and also deep.
I started pulling the old caulk out with a butter knife, but there's many feet to do. What hand tool would make removing the old caulk easier -- A caulk removal tool? A "QEP" grout removal tool? Or ... ?
Then what is more appropriate to refill the gap: Caulk, or grout? I've read that caulk should be used at "plane" transitions, but I wasn't sure the curved tile was considered a plane transition. And what kind or caulk/grout? Any tips for what tools to use to apply it, and any that would help give it a nice finished look?
In case you can't tell I've never done any tile work before, so thanks very much for any help! / Rav
Need help re-caulking/grouting wall tiles-beforeannot.jpg
Rav is offline   Reply With Quote
Old 01-05-2013, 05:49 PM   #2
Unless that floor is flexing in my opion that area should have been grouted not caulked.
Old 01-05-2013, 06:19 PM   #3
all corners where tile meet should be caulked, grout will just crack with the movement of the floor and walls.
Old 01-05-2013, 08:05 PM   #4
That's not a corner, it looks like where the sanitary base meets the wall tiles.
Old 01-05-2013, 08:45 PM   #5
Super Moderator
What a shame---sloppy work---you will have some time into removing that---a Multi-tool will aid in getting the old caulk removed---Harbor freight makes a good one at a fair price---
then it's hand work--razor blade--possibly a solvent like xylene (Goof off) and a scrub pad--
After it's clean I suggest you use a sanded tile caulk----they are available in all grout colors.
Old 01-05-2013, 08:55 PM   #6
this is the tool i use to remove caulk
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
oh'mike (01-05-2013)
Old 01-05-2013, 11:26 PM   #7
right joe, it looks like a ledge about an inch wide behind the tile now that i look at it more closely. is that bath paneling on the wall?
Old 01-06-2013, 06:53 AM   #8
Super Moderator
House is from 1931----it's most likely a porcelain tile---
Old 01-06-2013, 04:34 PM   #9
Tileguy
JazMan's Avatar
The floor tiles are porcelain, the wall is ceramic and so is the A106 cove tile. I can assure you it is not all original, (probably none of it).
I agree it is very sloppy work, the old HO's must have done it themselves. What's with the narrow grout line on the wall?
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Tags
caulk, grout, tiles, wall
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
How to enhance colour of textured wall tiles HeidiT Interior Decorating 1 03-27-2012 09:30 PM
Replacing bathroom wall tiles Shutterbug7 Carpentry 4 11-08-2010 11:04 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
How to diagnose problems with wall kahlan General Discussion 5 10-22-2008 10:18 AM
