-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Need help re-caulking/grouting wall tiles (http://www.diychatroom.com/f84/need-help-re-caulking-grouting-wall-tiles-168312/)
Rav 01-05-2013 02:18 PM
1 Attachment(s)
I'm not sure this is the right forum (since what I have is bathroom wall tile and this forum says "flooring"); if not, please direct me to the right forum.
Please see picture below. The tile on our bathroom wall is probably original to our 1931 house. At least a few decades ago someone re-caulked one area, doing a sloppy job, with the wrong color, and it's cracking. I assume what they used is caulk -- it's "rubbery." The area they caulked is between the last row of flat tile at the bottom of the wall and the "curved" tile (which butts up against the floor tile).
I want to remove all the old caulk and re-caulk (or re-grout?) it. The gap to be done is 1/4 inch wide and also deep.
I started pulling the old caulk out with a butter knife, but there's many feet to do. What hand tool would make removing the old caulk easier -- A caulk removal tool? A "QEP" grout removal tool? Or ... ?
Then what is more appropriate to refill the gap: Caulk, or grout? I've read that caulk should be used at "plane" transitions, but I wasn't sure the curved tile was considered a plane transition. And what kind or caulk/grout? Any tips for what tools to use to apply it, and any that would help give it a nice finished look?
In case you can't tell I've never done any tile work before, so thanks very much for any help! / Rav
joecaption 01-05-2013 04:49 PM
Unless that floor is flexing in my opion that area should have been grouted not caulked.
DannyT 01-05-2013 05:19 PM
all corners where tile meet should be caulked, grout will just crack with the movement of the floor and walls.
joecaption 01-05-2013 07:05 PM
That's not a corner, it looks like where the sanitary base meets the wall tiles.
oh'mike 01-05-2013 07:45 PM
What a shame---sloppy work---you will have some time into removing that---a Multi-tool will aid in getting the old caulk removed---Harbor freight makes a good one at a fair price---
then it's hand work--razor blade--possibly a solvent like xylene (Goof off) and a scrub pad--
After it's clean I suggest you use a sanded tile caulk----they are available in all grout colors.
epson 01-05-2013 07:55 PM
this is the tool i use to remove caulk
http://ts3.mm.bing.net/th?id=H.47088...38358&pid=15.1
DannyT 01-05-2013 10:26 PM
right joe, it looks like a ledge about an inch wide behind the tile now that i look at it more closely. is that bath paneling on the wall?
oh'mike 01-06-2013 05:53 AM
House is from 1931----it's most likely a porcelain tile---
JazMan 01-06-2013 03:34 PM
The floor tiles are porcelain, the wall is ceramic and so is the A106 cove tile. I can assure you it is not all original, (probably none of it).
I agree it is very sloppy work, the old HO's must have done it themselves. What's with the narrow grout line on the wall?:huh:
Jaz
