Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 01-13-2013, 06:58 AM   #16
Super Moderator
Need help framing ceiling of shower for tile, ATYPICAL STYLE
I never used a backer rod----
Have you looked into the Schluter system? I have never used it myself---
How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
My shower pans are built similar to this---then the walls and ceiling in a steam shower are sealed with Latacretes Hydroban.
Old 01-13-2013, 10:18 AM   #17
Still going...
ChrisDIY's Avatar
Thanks Mike!
That is actually the page I lost that I was looking at when I decided to make this closet a shower!
Sent from my Samsung Galaxy Tab 2 using DIY Chatroom
--Chris the DIY Guy
Still going, on Ibuprofen...
ChrisDIY is offline   Reply With Quote
Old 01-13-2013, 10:35 AM   #18
Super Moderator
Those steam showers are very enjoyable----and not all that difficult to do well--with the modern surface membranes available success is much easier than the old days----
Plumbing in the steam generator needs to be considered----they have a condensation drain --so don't forget about that when doing your rough in---Some will have a condensate drain that can be fed back into the shower----
Good idea to have the installation instructions for you unit when planning this out.
Don't forget about electrical requirements----Mike-----
Old 01-13-2013, 11:52 AM   #19
Still going...
ChrisDIY's Avatar
Thanks!
Just had a sub-panel installed just for this purpose.
--Chris the DIY Guy
The Following User Says Thank You to ChrisDIY For This Useful Post:
oh'mike (01-13-2013)
Old 03-05-2013, 10:12 PM   #20
Still going...
ChrisDIY's Avatar
Does it matter if the cement board stops short of the mud pan (caulk gap) vs. having board go down to shower pan liner (caulk gap) and be inside and part of mud pan? Finding diagrams of both ways.
--Chris the DIY Guy
Old 03-06-2013, 06:09 AM   #21
Super Moderator
As long as the deck mud will be packed against the Durrock ans hold it in place--it will not matter how close to the liner/ preslope it is---
custom tile shower ceiling maljeff Drywall & Plaster 1 08-21-2012 11:07 AM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Threaded shower head connection too close to ceiling anygren Plumbing 6 10-11-2010 02:41 PM
replacing ceiling mount shower head JoanneW Plumbing 3 05-31-2010 09:19 PM
Is it ok to use the shower without a ceiling in the bathroom? Bigguy0 Building & Construction 5 10-24-2009 08:26 PM
