Need Generic Tile/grout Color Opinions - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 09:34 PM   #1
Rewards Points: 77
Need generic tile/grout color opinions
Tiling a kitchen, breakfast bar area, dining room, and bathroom. Currently a combination of vinyl sticky tile and beat up parquet. Going to cover both with a backerboard first. But my question is a generic one about the color of the tile. I'm going as cheap as possible since the house is going on the market the day we finish this project, so I know my choices will be beige, tan, white, grey...or some variant of those colors. But I'm curious if I'd be better off going with a lighter or darker tile. Same with grout. Which makes a room look bigger? Does it matter?
Currently we have stained oak cabinets, black laminate countertops (that faux-granite crap), and a darker tan wall. Just looking to see if there are any tried-and-true color opinions out there.
Proulx06 is offline   Reply With Quote
Old 12-12-2009, 10:45 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 412
I'll leave the color issue to someone else.
You said; "Going to cover both with a backerboard first."
That would be a very bad move. You need to remove both of those floor and if the house has plywood floors chances are you also have some kind of 1/4" underlayment which needs to be taken to the curb.
Then you can install a backer board into fresh thin set mortar, tape etc., then the tiles.
Jaz
Old 12-12-2009, 10:53 PM   #3
Rewards Points: 77
Not doubting you, but the only other tile job I did was about five years ago when I did the same thing (backerboard over vinyl). Looks great to this day. What are the risks involved?
Old 12-12-2009, 11:56 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 412
Although it's not the right way, you could get away with the vinyl part most of the time. One issue is 1/4" luan & OSB underlayments are very unstable for example. If they get damp, they're toast and so is the new floor. The parquet is the one that you simply don't want to go over with any backer, not even plywood.
Jaz
Old 12-13-2009, 06:58 AM   #5
Total failure.
R&D Tile is offline   Reply With Quote
advice on tile/grout sealer for polished marble in shower marcin1 Flooring 4 05-18-2008 06:59 AM
Tile/Grout problems BigA Flooring 4 07-22-2005 04:54 PM
