Is My Contractor Installing This Backerboard Correctly. - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-24-2014, 11:20 PM   #1
Rewards Points: 33
is my contractor installing this backerboard correctly.
Hello
My contractor says this is fine but I dont think so.
He is installing 1/2 inch hardibacker around my tub but it is really bowing out at the bottom. When I go to lay the tile it will really bow out. He has also scratched up the new tub and he did not even put the tile liner in the tub. I think I need to fire him but dont know how.
Do these pictures look right?
Please help!
THANK YOU IN ADVANCE!
is my contractor installing this backerboard correctly.-20140324_214003.jpg   is my contractor installing this backerboard correctly.-20140324_213743.jpg
mlpluess is offline   Reply With Quote
Old 03-24-2014, 11:35 PM   #2
Rewards Points: 6,652
What is the first picture. Can you stand farther back to show the whole big picture.
As for the Backer board, it is supposed to not be in direct contact with the tub. Otherwise if any water seeps past the caulk that goes between the tile & tub. The Backer Board will soak it up, and cause the tile to loosen up over time.
Old 03-24-2014, 11:37 PM   #3
Rewards Points: 33
The first picture is the Hardibacker in front of the lip of the tub. It is in a corner so I cannot get a better picture but I will try on the other wall.
Old 03-24-2014, 11:41 PM   #4
Rewards Points: 33
Are these better?
is my contractor installing this backerboard correctly.-20140324_223815.jpg   is my contractor installing this backerboard correctly.-20140324_223825.jpg
Old 03-24-2014, 11:44 PM   #5
Rewards Points: 33
Should the Hardibacker be up on top of the lip? I see that in a bunch of videos.
Old 03-24-2014, 11:45 PM   #6
BTW, your finger was in the way on the second picture. Yep, that is not installed correctly. Is this a Handyman, or a real licensed contractor. Majority of the areas require Handymen/women to be licensed. Mine happens to be one of them.
Of course a lot of them sneak under the radar. As long as they are not reported to the local AHJ office, or State's AG.
Old 03-24-2014, 11:46 PM   #7
Now step farther back, put some more light in the room, and show the whole tub of what the Big picture looks like, not just sections.
If you are using a iPhone or Android. There is the DiyChatroom app in the iPhone App Store and Google Play store for Android devices. It allows you to post larger scaled images.
Old 03-24-2014, 11:48 PM   #8
Rewards Points: 33
He actually works construction, new and old. He has been doing it for over 20 years and I went to school with him. He posts his stuff on facebook all the time so I figured this was a small job so it could not go bad. My father got sick in the middle of assisting me so I needed help. I will have to get someone else. Should the Hardibacker be installed to rest on top of the lip of the tub and then I caulk below that?
Old 03-24-2014, 11:52 PM   #9
It is a nice gesture to have a friend do it. But at times like these, you need to just have them stop before they go any further. You have already stated that he did not lay any cardboard or place protective plastic inside the tub to protect it.
That right there is a big Red Flag. Then having the Backer Board not trimmed properly is another one.
I am asking for this to be moved over to the tiling forum, from the Drywall and plaster forum. There are some regulars over in that section, that can further be of assistance to you on this.
Old 03-24-2014, 11:59 PM   #10
Rewards Points: 33
More pictures.
is my contractor installing this backerboard correctly.-20140324_224951.jpg   is my contractor installing this backerboard correctly.-20140324_225026.jpg   is my contractor installing this backerboard correctly.-20140324_225053.jpg   is my contractor installing this backerboard correctly.-20140324_225125.jpg   is my contractor installing this backerboard correctly.-20140324_225150.jpg
Old 03-25-2014, 12:01 AM   #11
Rewards Points: 33
More pictures continued
is my contractor installing this backerboard correctly.-20140324_225302.jpg   is my contractor installing this backerboard correctly.-20140324_225331.jpg   is my contractor installing this backerboard correctly.-20140324_225347.jpg
Old 03-25-2014, 12:02 AM   #12
Rewards Points: 33
Thanks for your help!
Old 03-25-2014, 12:04 AM   #13
Yep you have issues. He should have just cut those two sheets on the back wall, so that he would have at least a 2' piece to go in between the two sections.
Since it is just screwed in at this point (hoping that he did not use some type of glue first, to hold the panels to the Studs), you should be able to just pull them and redo them.
The best way to do the gap is to use a shim and the wide end sits between the tub & sheet. Then you would fill with Caulk before tiling, to help create a seal between the tub & boards. Then when you put up the tiles, you want at least a 1/16" gap between the tub & tile, with that area sealed with caulk. Same with the vertical corners, where the sides & back meets.
Old 03-25-2014, 12:06 AM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 348
Thread moved- let's let the pros look at it, but Gregzoll's right - your board install is wrong.
The Following User Says Thank You to TheEplumber For This Useful Post:
gregzoll (03-25-2014)
Old 03-25-2014, 12:06 AM   #15
Rewards Points: 33
Thanks! The backerboard will still be a little bowed out at the bottom, should it be or do I need to shim the wall?
backerboard thinset and backsplash agamm Tiling, ceramics, marble 10 01-22-2012 03:31 PM
Backerboard, tile, tub installl kathyll Building & Construction 26 02-15-2011 09:35 PM
Question about how to position backerboard for shower Swazzle Remodeling 3 08-03-2010 06:11 AM
Backerboard and Tile Project Question Livestrg05 Flooring 6 04-25-2009 08:35 AM
Curved backerboard? mdalli Remodeling 7 04-22-2008 03:24 PM
