Mortar Question For Travertine And Granite Tiles. - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 09:38 AM   #1
Rewards Points: 150
mortar question for Travertine and Granite tiles.
I am going to start laying my floor (18x18 Travertine) and bar top (12x12 Granite tiles). I was wondering what would be the best notch size for the mortar? Travertine will be on concrete floor and granite will be on backerboard.
Thanks!!
Abs777 is offline   Reply With Quote
Old 06-09-2011, 09:31 AM   #2
Rewards Points: 150
For the people who have laid travertine on concrete did you use a special mortar or some kind of adhesive to help it adhere better? Also as stated above, what is the best trowel notch size for tile that size and how big of spacers would you use?
Any help will be much appreciated.
Old 06-09-2011, 10:06 AM   #3
DIY staff
Rewards Points: 7,174
18x18---I'd use 1/2 x 1/2 trowel---modified thinset (powdered)
spacing is your choice---I suggest you see if 3/16 looks good to your eyes.
Lippage can be a big problem with 18 x 18 tiles---consider a leveling system like Lash by QEP
or Tuscan or Ramondi---they pull the tiles nice and flat----Back buttering the tiles is a good idea when using a leveling clip.
Old 06-09-2011, 10:39 AM   #4
Rewards Points: 150
Thanks for the info Mike. Couple questions....
What exactly is modified thinset?
What is lippage? Lip high in spots?
Also what do you mean by leveling clip?
Sorry just not well versed in tiling. I've done easy ceramic before, but that was on sub floor and not concrete.
If the floor is in great shape and level do I still need a leveling system?
Old 06-09-2011, 03:28 PM   #5
DIY staff
Let's start with the setting material----Thinset is a powdered cement based mortar used to stick the tiles to the concrete.
It comes as unmodified (just cement) or modified (contains a latex powder) which makes it stickier and more flexible.
Sometimes unmodified is mixed with a liquid latex --this makes for a very good bond over certain surfaces.
For your job I suggest a modified thinset --I like white for natural stone.
Lippage is what happens when one tile edge stick up more than the one next to it.
The larger the tile the more this becomes a problem. Floors need to be flat--no more than 1/8 inch in 6 feet.---Google the clips that I listed--you will see what they do.
I use them on any tile larger than 14"---
The thinset must be mixed with a strong 1/2" drill with a mixing wand.
Do not use any pre-mixed adhesive---ever---use the powdered stuff.----Mike---
Old 06-09-2011, 03:43 PM   #6
DIY staff
Here is some good reading for you---"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
Tuscan Leveling System - Flooring Picture Post - Contractor Talk - Professional Construction and Remodeling Forum
LASH System by QEP
Old 06-10-2011, 10:28 AM   #7
Rewards Points: 150
Thanks Mike for all of your info. I really appreciate the help!
The Following User Says Thank You to Abs777 For This Useful Post:
oh'mike (06-10-2011)
granite transformations El Toro Remodeling 241 01-27-2017 11:23 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
granite tiles on walls of shower mordon Building & Construction 2 04-13-2009 06:45 PM
granite floor tile which mortar? diy888 Flooring 10 01-23-2009 08:20 AM
Granite tile counter question ryguy Flooring 3 09-27-2007 12:31 PM
