More Ceramic/Lino/concrete Question - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-21-2014, 06:58 PM   #1
More ceramic/Lino/concrete question
Couple of new questions about upcoming DIY ceramic tile job. The
It appears the Lino tiles mentioned in previous post are going to need to come up after I pulled the rest of the carpet up. In my previous post I was told I would need to remove the mastic that was used from the concrete slab for the ceramic to adhere. Can anyone recommend a solvent/process? It looks like the mastic has stained the concrete. Will I need to get the stain out as well? Beginning to look like too much time and work if so. Could a new substrate (cement board or plywood) be attached to the slab using construction adhesive and then tiled? The slab is 70+ year old and very hard. Maybe the best solution is new carpet Thanks
Mike in Arkansas is offline   Reply With Quote
Old 01-21-2014, 07:33 PM   #2
DIY staff
Rewards Points: 7,174
It's not that big of a chore----first of all---no solvents---they will soak into the concrete and become a bond breaker.
After the tiles are removed---use a razor scraper to remove as much as you can---there are long handled ones available in the tile section of most stores--
If that isn't removing enough of the cutback---pour some hot water (boiling if you can) over the mastic--and have another go with the razor scraper--
Let it dry out--then set the tiles with a two part thinset like Kerabond and Keralastic--or a modified thinset approved for use over cutback--
I've also encapsulated cutback using Jifset mixed with Linewebers liquid latex---
Old 01-21-2014, 10:05 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 290
No, no, that would be so unsanitary. But yes, it's easier and cheaper in the short term.
You can not use solvents to remove the adhesive. You need a razor scraper and knee pads cuz you're gonna be at it awhile.
No concrete backer or plywood, that would be a bad move.
Jaz
More ceramic/Lino/concrete question-scraper-.jpg
JazMan is online now   Reply With Quote
Old 01-21-2014, 10:38 PM   #4
Thanks. Started getting up the Lino tiles tonight before running out of gas. For the most part they come up easily (some popping up whole) using a garden edger. Kind of a hoe but the blade extends straight from the handle. A lot easier than I anticipated . I have found some cracks in the slab and I'm going to be patching in places so is an isolation membrane a good idea? If I find the floor isn't flat I'll try some leveling compound once the glue is up unless there is a reason I shouldn't. Appreciate all the great advice, Mike.
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 02:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
