Mixing / Stretching Thinset Types - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-17-2014, 03:26 PM   #1
Rewards Points: 81
I've got my bathroom walls tiled and am down to 32 square feet of floor left to do with 12x24 glazed porcelain tiles. I have been using Custom Building Products Marble/Travertine mortar. I had to mix about 1/3 of a bag to finish the walls, so I am down to about 2/3 of a 50 pound bag, or enough to cover about 30 square feet with a 1/2 x 1/2 trowel that I have been using. That is cutting it a little bit close.
I would really like to avoid buying another $30 bag to throw 90% of away. I have about 25 pounds of Mapei Non-Modified mortar I used under the cement board on the floor. Can I add five pounds or so of this mortar to the marble mortar to stretch it? Floor is 3/4" T&G plywood, 1/2" plywood and 1/2" Durock over thinset if it matters.
Obviously I don't want to mess up my floor to save $30, but would also prefer to avoid more waste.
tev9999 is offline   Reply With Quote
Old 02-17-2014, 06:44 PM   #2
Personally I don't see anything wrong using any old tile mortar to finish her off. But then again, is 30 dollars worth that mess? I would spring for the bag and keep it incase anything ever happens and you need to pop a tile or two.
Mross91 is offline   Reply With Quote
Old 02-17-2014, 07:28 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 232
I don't see a problem doing what you said. However, you are changing the formulation in at least two ways.
1. By adding unmod. you will end up with a lesser grade of modified mortar.
2. The sand in the cheaper mortar is not rated Medium Bed as is the Marble Granite Travertine. The tiles may sag a bit, but maybe not. It's a small ratio and I have no way of knowing.
If you try to save the $$$, be sure to mix enough cuz you can not use the unmod alone. If you do not mix enough you can get a qt. of additive and still use the unmod. thin set though.
Jaz
JazMan is online now   Reply With Quote
Old 02-27-2014, 09:29 PM   #4
Rewards Points: 4,784
I think JazMan is on the right track. Mix in a bit of additive and you should be fine.
jeffnc is offline   Reply With Quote
impact driver for mixing thinset? Amateuralex Tools 29 09-27-2012 03:36 PM
Temperature requirement for MIXING (not applying) thinset gzenar0sa General DIY Discussions 5 12-10-2011 12:45 PM
Mixing Mastic and Thinset in a Tile Job smata67 Building & Construction 2 08-09-2009 11:38 PM
Mixing thinset simonb Flooring 32 07-04-2008 03:07 PM
