Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 06-25-2012, 12:45 PM   #1
Mixing paddle
Just a simple question, probably a dumb one but want to make sure.
Can you use the same universal mixing paddle for mixing grout and thin set but washing it completely before using it?
Like say I mixed all my thin set mortar and I have enough blah blah blah. Then I have someone or myself wash the paddle so it looks brand new and use that to mix the grout another day.
omniszero is offline   Reply With Quote
Old 06-25-2012, 01:02 PM   #2
Super Moderator
Mixing paddle
If the paddle is clean--sure--
I always hand mix the grout--I just use a margin trowel--Even on a big job. Mike--
Old 06-25-2012, 10:33 PM   #3
Mixing paddle
I don't know if it will work if it is completely clean, but I know it works fine if it is coated with thinset.
cleveman is offline   Reply With Quote
Old 06-27-2012, 10:13 AM   #4
yummy mummy's Avatar
Mixing paddle
When I did my tiling work, I did clean the mixing paddle every time I used it. Even though I was not planning on using it anytime soon.
Good luck with your work.
yummy mummy is offline   Reply With Quote
Old 06-27-2012, 11:40 AM   #5
Mixing paddle
ty guys. Ya I was just unsure was all. I hate doubting my own concsious.
Thank you again
Tags
grout, paddle, washing
soldering copper pipe on a shower mixing valve. Ed911 Plumbing 7 05-17-2012 10:27 AM
Moving/Installing new mixing valve... issues with framing rodney23 Plumbing 6 12-12-2010 04:32 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 11:01 PM
shower mixing valve mdm101 Plumbing 2 12-12-2009 09:58 AM
