Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 05-07-2012, 08:42 PM   #1
Mastic for shower wall tiles
Ok so I am just about to start tiling (tomorrow hopefully) my newly constructed bathroom shower/tub. I have put up concrete board. I was told by a manager at Home Hardware to use mastic in the shower for the tile because it is much easier to use, etc. etc. I just had Mike Holmes on in the background and heard him say never to use Mastic in wet areas. So I jumped online quick to read up on it and saw a few blogs on here saying never to use Mastic. Two questions:
A) If it is Mastic that is meant for wet areas is that ok or should I use dry un modified thinset?
B) I have already used the Mastic over the joints in the concrete board. Can I now change to thinset or will it not adhere where the mastic is?
I'm annoyed because I already spent $50 on the Mastic but I want this done right.
ashton44 is offline   Reply With Quote
Old 05-07-2012, 08:47 PM   #2
Take it back, never that a box stores advice. But while your there pick up the Red Guard you forgot to pick up to water proof the tile board.
Tile board is not water proof.
Old 05-07-2012, 09:32 PM   #3
JetSwet's Avatar
Definitely easier to work with tile glue then using thinset although no one here will recommend using it anywhere except backsplash on kitchen.
I have use it in showers and none has failed although I don't anymore just because its over all not a good idea.
What size tile are you using? I say if your already using the tile glue then let hope your tile size isn't any bigger then 4-6"
JetSwet is offline   Reply With Quote
Tags
bathroom, cement board, mastic, tile
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-13-2012 12:36 AM
self sticking tiles - wall application peter_d_holmes Tiling, ceramics, marble 12 03-13-2011 06:18 PM
Replacing bathroom wall tiles Shutterbug7 Carpentry 4 11-08-2010 11:04 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
How to diagnose problems with wall kahlan General Discussion 5 10-22-2008 10:18 AM
