Marble Fireplace Surround - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 10:56 AM   #1
Marble fireplace surround
What is the difference between thin set mortal and thin set with latex additive? I am trying to install marble top header for my marble fireplace surround that broke. i don't want this set to break again.
amoks is offline   Reply With Quote
Old 12-10-2011, 10:59 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The difference isn't great enough to correct what you are doing.
Are you applying thinset to the tile and then thinking you can slap it on the wall and it's going to stick and stay? Is that correct?
Old 12-10-2011, 11:17 AM   #3
Yes, the marble seller said I should apply the thin set and slam it on the wall, that it would stay, so I want to be sure they are right. Or what is the best way to go about it. It's only the header part of the marble surround that broke. I bought the piece and trying to fix it back on the marble fireplace surround. The mable company told me thin set mortal. I checked online now I saw thin set with latex additive so I want to be sure which is the best to use? Thanks a lot for any help.
Old 12-10-2011, 11:29 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow well he's an IDIOT and as you have seen just as wrong as he can be.
"Slam it on the wall". Is that his words or yours?
You don't learn from your mistakes do you? Maybe neither is best in this case.
Why don't you throw up a photo here so we can see what it is you think you want to do.
What exactly is this marble piece you are trying to install? Let's see a picture.
tile fireplace surround and floor-help. moyni51 Flooring 1 08-07-2011 07:50 AM
Natural Marble as a tub surround jkalin Tiling, ceramics, marble 4 03-03-2011 11:35 PM
Access Door Panels For Tiled Fireplace Surround Fire4Effect Tiling, ceramics, marble 0 09-07-2010 01:12 PM
Need some help with Fireplace base and surround bowanna03 Carpentry 4 03-14-2010 04:37 PM
How can you cut marble round a fireplace stu_mchugh Remodeling 1 02-17-2008 01:11 PM
