Making A Full Circle In A Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-11-2009, 12:16 PM   #1
making a full circle in a tile
Hi
I want to make a circular hole (50mm diameter) in a tile, the tile i have not yet decided upon... I would preferably like granite/marble so which is the best machine/tool to use to make a hole and any general tips would be great
shabba
shabba1985 is offline   Reply With Quote
Old 12-11-2009, 07:49 PM   #2
Hi
shabba
Old 12-11-2009, 07:56 PM   #3
A diamond cutting wheel. Cut the hole smaller and then abrade it to the desired diameter.
Old 12-11-2009, 08:00 PM   #4
who do i go about abrading the tile? shall i use a disc to smooth around the edge?
also what kind of diamond cutting tool i am guessing i will need a drill piece similar to that of cutting a small hole in plasterboard for spot lights.?
Any other useful tips regarding the cutting would be appreciated
thanks
Old 12-11-2009, 09:44 PM   #5
http://www.grainger.com/Grainger/wwg...headSearch.y=8
Old 12-12-2009, 09:25 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OK, a circle for what reason. Be more specific, what the heck are you doing?
XXX
Old 12-12-2009, 09:34 AM   #7
the Musigician
DangerMouse's Avatar
funny you should ask... we were just discussing that here:
Drill bits for tile?
DM
Old 12-12-2009, 04:13 PM   #8
I am going to spot lights into granite coming from the worktop.... I will put up pictures once I have accomplished this lol, I am sure it will look great...
Old 12-12-2009, 08:18 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Allrightee then!
Standard round light fixtures have covers. If this is the case the cover is going to save you. You can use a RotoZip with a diamond blade to cut the hole but it won't be that purdy. You'll need the cover-ring to hide the imperfections but it can be done.
XXX
Old 12-12-2009, 09:30 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
shabba,
How many different threads did you start here with this same identical question? What's the point in that?
XXX
Old 12-13-2009, 12:05 AM   #11
Get out of the box!
Rewards Points: 260
We use a drill with 2" carbide hole bit, you can find them at most HDs
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Old 12-13-2009, 07:50 AM   #12
shabba,
i started 2 different threads in different sections... the point is obvious
also i am new here so didnt know which was the best place to but it... do you have any suggestions to my initial thread, if so please post in both places lol
Old 12-13-2009, 07:53 AM   #13
i have been looking at these, but i can not seem to find 4.5mm diameter ones, this one could be the thing i am after
Old 12-13-2009, 08:45 AM   #14
2 threads on the same issue merged
Please only 1 thread on an issue
-Dave
Old 12-13-2009, 03:34 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The hole doesn't have to be the absolute exact size of the fixture. A little larger won't hurt anything. The 2" bit (hole saw) will do the trick.
XXX
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 01:59 PM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 02:02 PM
