Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 11-29-2012, 08:32 PM   #1
Main Door Entrance
I'm going to lay ceramic tile on the main entrance floor. It has a plywood floor underneath the old vinyl tile. The space is about six feet wide x three feet wide. Is it okay to lay the wire, on top of the plywood, or should I use a different product. The tile's are 12"x12"
holy2rob is offline   Reply With Quote
Old 11-29-2012, 08:33 PM   #2
Main Door Entrance
Thank you for the invite
Old 11-29-2012, 08:42 PM   #3
Super Moderator
Main Door Entrance
Welcome----I don't know what wire you speak of----If you are talking about expanded metal plaster lath---skip that--and go to a 1/4" cement backer board like Wonder Board or Durrock set into a bed of fresh thinset and nailed with roofing nails----much safer method---tell us more about the project---Mike----
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Main Electric Panel Help Redrum Ninja Electrical 13 10-22-2011 08:28 PM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 05:52 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
