Looking For Input On How To Redo My Kitchen/laundry Room Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-26-2014, 10:52 AM   #1
Rewards Points: 155
Looking for input on how to redo my kitchen/laundry room floor
I am looking to redo the floor in the laundry room and kitchen. Attached is a not to scale in anyway picture of layout.
Both rooms have a laminate sheet and adhesive paper underneath it. Then i drilled a hole through the floor under the fridge and the subfloor is 1 1/2" thick.
The joists run the same way as the wall in the middle and they are 16" on center. Look to be 2x6' i think. i do not recall.
i am looking to remove the laminate and then put put down the ceramic tile that looks like wood.
do i need to remove part of the plywood to get cement board down. then thinset and then mastic and then the tile?
please give all suggestions and feedback
rygar is offline   Reply With Quote
Old 08-26-2014, 01:23 PM   #2
DIY staff
Rewards Points: 7,174
First thing--we need to know the strength of the floor joists---post the joist size--type of wood if you can find a stamp--spacing (16" I believe you mentioned) and the unsupported length (beam to foundation?)
once you have stripped off the old flooring and the 1/4" ply underlayment (if there is one)--you are ready for your tile backer.
1/4" Durrock or Wonder Board is my favorite---set that into a bed of fresh thinset (the powdered kind) then nail with roofing nails or the fancy Rock screws---
Set the tiles using thinset mortar---
If height is a concern--Schluter and others have a 1/8" thick membrane that works well---
Old 08-26-2014, 01:57 PM   #3
Rewards Points: 155
the joists almost sit on top of the concrete in the basement. i will double check and take a picture when i get home.
The Following User Says Thank You to rygar For This Useful Post:
oh'mike (08-26-2014)
Old 08-26-2014, 01:58 PM   #4
DIY staff
Someone will figure out the deflection for you---Mike---
Old 08-26-2014, 03:23 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What does that mean: almost?
Need to know: (No "I thinks" allowed)
The style of the floor joists.
The size of the floor joists.
The spacing between floor joists.
The wood species if possible.
The unsupported span of the floor joists.
The subfloor material in place.
The subfloor thickness.
Any additional layers of (whatever) may be there. I would be surprised if the subfloor was 1-1/2" thick, that would be highly unusual.
XXX
Old 08-26-2014, 06:51 PM   #6
Rewards Points: 155
OK. i just got back from the basement. It seems that my numbers were off.
1) The joists are 2x8
2) The joists are 14" on center
3) The span between the foundation and center beam (ranch house) is 10 1/2'
4) The joist over the 1 1/2" over the foundation
5) Pine wood, i didnt see any kind of stamps. everything is insulated.
6) Subfloor is plywood
7) Since they put laminate in the floor i bet the subfloor is 3 layers of 1/2" plywood. i drilled a hole through the floor and measured 1.5"
8) The 1.5" gap above the foundation has what a appears to be a 2x4.
please see new pictures attached
Old 08-26-2014, 07:22 PM   #7
DIY staff
You are good for tile----deflection (based on 16"centers) is 425---
360 is safe for tile---720 would be needed for natural stone----
If the joists are indeed 14" centers--you have 485---even better for tile--Mike---
Old 08-26-2014, 07:25 PM   #8
Rewards Points: 155
well thats good to know. now about the subfloor. i am hearing two things from people and contractors i had do estimates. one said never do floor tile on cement board and that sounded crazy and then lots of people are telling me that i need to get rid of the top layer of plywood and put down cement board. i am just trying to keep the height pretty close and making sure i do this the right way like the pros do it.
Old 08-26-2014, 08:12 PM   #9
DIY staff
You need to know what you have---first thing--at the age of the house you may have 1x6 pine subfloor---then ,rather likely,a layer of 1/2" plywood9or thicker) them an underlayment for the old vinyl tile---
If you have the pine subfloor--(move the insulation aside and look) that alone is no good for tile---it moves to much--so you want a layer of plywood on top of that---1/2" minimum----then a backer for the tile--could be 1/4"cement board or a sheet membrane like the Schluter product.
Sticking tile directly to any wood is not a safe plan.
Old 08-26-2014, 08:22 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Utter nonsense...tile is why they make cement board.
XXX
Old 08-26-2014, 09:04 PM   #11
Rewards Points: 155
looking up from the basement it is definitely plywood and it looks pretty new. its def not 1x6 pine
Old 08-26-2014, 09:05 PM   #12
Rewards Points: 155
and this is why i am here and not working with that contractor.
Old 08-26-2014, 09:11 PM   #13
DIY staff
You sound good for tile--you won't know exactly what you are up against until you demo the old coverings--but the structure is fine.
Old 08-26-2014, 09:17 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow well there is something wrong with that guy. Can't imagine what agenda he must have. You would be wise to lose his phone number.
XXX
Old 08-26-2014, 09:21 PM   #15
Rewards Points: 155
would a toe kick saw be a good bet to remove the old top underlayment?
what is the best practice to find out exactly how many layers in the subfloor even after i drilled a hole in it. upon inspection i could not tell how the layers work. should i cut out a 1"x1" square with the sawzall?
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Cold room under stairs (dirt floor) questions with pics burnt03 General DIY Discussions 14 06-07-2012 09:05 AM
Living room floor Barry J Flooring 1 04-13-2012 01:50 PM
Divided room on second floor kemp Carpentry 5 09-27-2009 04:09 PM
