Leveling Bath Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 12:39 PM   #1
Leveling bath floor
Do I have to use self leveling compound to level a 6 x 6 bathroom floor before laying tiles (Hardi board already down/seams taped) or can I level it myself with quickcrete that states it is used to level floors? Why am I asking? The slc is $38 - $40 and the quickcrete is $4.58/bag.
amgdiy
amgdiy is offline   Reply With Quote
Old 12-04-2011, 12:42 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
How much levelling do you have to do?
Levelling a floor and "planing" a floor can be two different things.
Quickcrete doesn't usually work for this purpose. Exactly which Quickrete product are you referring to?
XXX
Old 12-04-2011, 01:14 PM   #3
Not much leveling at all which is why I did not want to spend much $. The quickcrete is a fast-setting "underlayment" and states that it is appropriate for leveling floors. But, no mistake. If I have to spend the $ I will b/c the tiles are a grade 5 porcelain AND are 24"x12". So I will listen to your advice. Also do I need a primer? If so, what do you recommend?
Old 12-04-2011, 01:18 PM   #4
Oh and I have to level not even a 1/4" in a few places on the floor. Thank you so much.
Old 12-04-2011, 01:56 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay, if that product is for patching and you have no more than 1/4" to fill I assume it will work. As long as it isn't Quickrete sandmix or concrete with aggregate in it. Quickrete makes many products for many purposes.
I would however use a long straightedge to drag and finish the fill, spot placing with a small trowel probably isn't the best way to do it.
Tiles that big DEMAND that a substrate be "plane", not necessarily "level" but flat.
I don't think the SLC is the product to use for this application.
Primer shouldn't be required with that product unless that's what the instructions say to do.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
amgdiy (12-04-2011)
Old 12-04-2011, 04:07 PM   #6
Thank you very much. It's what I wanted to hear. You are right about quickcrete. There are many different products. It took me a while to find that they made an underlayment expressly for "leveling" floors in preparation for laying ceramic tiles and hardwood floors. Thanks again.
The Following User Says Thank You to amgdiy For This Useful Post:
Bud Cline (12-04-2011)
Leveling an uneven bathroom floor - HELP! Teikas Dad Flooring 5 12-12-2010 08:39 AM
Applying self leveling floor compound over existing floor adhesive? rortiz Flooring 3 11-05-2009 08:41 PM
Leveling a basement floor with a well - help! monichan Flooring 2 03-14-2008 12:31 PM
Leveling concrete floor - problem McCool Flooring 3 12-05-2006 09:31 PM
Leveling wood floor helpless handyman Building & Construction 1 10-17-2006 10:06 AM
