Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 10-05-2012, 04:45 PM   #1
Leveling around Toilet Flange with Grout or Thinset?
Just layed floor tile with mortar. I was wondering about the Toilet flange I'm replacing.
I had previously already raised it up because it was 3 inches below with some cement. The area around the sewer pipe is still about a 1/4 inch beneath the tile.
This makes the toilet flange over the sewer hole a little unlevel.
Could I use GROUT (or THINSET) to level the tile floor up the extra little space to before putting in the new Toilet Flange?
Side questions:
which is more porous grout or thinset?
which is stronger and more structural?
if they are too porous for under the toilet would it make sense to put a sealer over it? I have redgard or I could just paint silicone caulk over it?
THANK YOU
crayola110 is offline   Reply With Quote
Old 10-05-2012, 07:30 PM   #2
I just used the thinset. I wanted to use grout, but realize that either way its not gonna be seen so i'm guessing thinset is stronger for the toilet to rest on
Tile around Toilet flange. Tile will be at Higher Level than Flange? crayola110 Tiling, ceramics, marble 0 09-19-2012 07:07 PM
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 01:18 PM
Toilet Flange Dilemma (W/ Pics) Rotate Plumbing 5 06-19-2011 07:00 AM
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 11:45 AM
Toilet closet flange kensington Plumbing 5 04-27-2008 09:19 AM
