Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 12-13-2012, 02:42 PM   #1
Lets talk tile floor prep
I am going to be tiling a room in a basement, the floor has been previously painted.
I Intend to grind the paint off the floor via wire wheel and sanding pads to get down to the concrete then clean with a damp sponge 3-4 times to get all dust off the surface.
The floor is uneven in several spots, so I plan to level them out prior to tile, should I use a self leveling mix or a patch? I am going to be using Mapei products for the job. What product is best recommended?
I plan to put down Mapelastic CI after grinding to prevent cracks and get a better surface to tile on.
I am somewhat unsure of what comes next, do I need to apply a primer over the patch prior to putting down the thinset and setting tiles or not?
My tiling experience has only been in rooms with a wood underlayment where we would put down cement board and thinset over that. any insight would be helpful.
Thanks!
bman27 is offline   Reply With Quote
Old 12-13-2012, 06:01 PM   #2
Super Moderator
Could you give us and idea what 'uneven in a few spots" means exactly---
Ardex Feather finish is good for thin patches---self leveling compound is the answer for hollows ---
Old 12-14-2012, 01:02 PM   #3
By uneven I mean there are a few areas between 4 and 8 sqft each where the floor is about 1/4-3/8" lower than the rest of the floor, it's basically a poorly floated floor IMO
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
