-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Lets talk tile floor prep (http://www.diychatroom.com/f84/lets-talk-tile-floor-prep-166379/)
bman27 12-13-2012 01:42 PM
I am going to be tiling a room in a basement, the floor has been previously painted.
I Intend to grind the paint off the floor via wire wheel and sanding pads to get down to the concrete then clean with a damp sponge 3-4 times to get all dust off the surface.
The floor is uneven in several spots, so I plan to level them out prior to tile, should I use a self leveling mix or a patch? I am going to be using Mapei products for the job. What product is best recommended?
I plan to put down Mapelastic CI after grinding to prevent cracks and get a better surface to tile on.
I am somewhat unsure of what comes next, do I need to apply a primer over the patch prior to putting down the thinset and setting tiles or not?
My tiling experience has only been in rooms with a wood underlayment where we would put down cement board and thinset over that. any insight would be helpful.
Thanks!
oh'mike 12-13-2012 05:01 PM
Could you give us and idea what 'uneven in a few spots" means exactly---
Ardex Feather finish is good for thin patches---self leveling compound is the answer for hollows ---
bman27 12-14-2012 12:02 PM
By uneven I mean there are a few areas between 4 and 8 sqft each where the floor is about 1/4-3/8" lower than the rest of the floor, it's basically a poorly floated floor IMO
