Ledger Board Question - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 04:56 AM   #1
Ledger Board question
Hello forum. This is my first post. I should of joined years ago. Here goes. I am tiling the walls surrounding the bathtub. Already have the cement board attatched. My question is why would a ledger board be needed? Can I just start from the bathtub with a gap using a 3/16 inch wedge all around between the tub and first row of tiles? Thanks for any input and appreciate your time. Thanks again...Ray...
fatboy1729 is offline   Reply With Quote
Old 03-09-2013, 08:19 AM   #2
Rewards Points: 150
U can but ledger board just let's u start with a straight line snd then once set go back and put in pieces on tub which most will have to be cut
kaschmid3 is offline   Reply With Quote
Old 03-09-2013, 11:44 PM   #3
Registered User
Rewards Points: 5,482
As said, many tubs are not perfectly level, especially at the ends- keep water from draining/running off side onto floor. Moving you to "Tile" for more answers, Gary
Bad Ledger Board Attachment dougp23 Building & Construction 2 01-03-2013 04:57 PM
No rim joist for ledger board. bp4577 Building & Construction 2 10-19-2012 10:54 AM
yet another cement board question echobravo Kitchen & Bath Remodeling 4 01-23-2012 04:39 PM
Re-attaching Deck to Ledger Board B-Web Building & Construction 5 12-13-2010 08:05 AM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 05:51 PM
