Ledger Board - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 11:13 AM   #1
ledger board
why use a ledger board and how high would you start from the shower floor ( ledger board ) I am using 12x12 tile
tjlacy is offline   Reply With Quote
Old 03-04-2011, 11:26 AM   #2
Experienced
Jackofall1's Avatar
Welcome Tj, to the best DIY'r site on the web.
I am sure that your question will be answered soon, by one of the many tile experts on this site.
Mark
Old 03-04-2011, 12:15 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 340
You temporarily install a ledger board to have a level support for the tiles. Usually I place it supporting the second row of tiles.
What are the walls made of? What type of shower floor/base are you installing? How about vapor barrier and /or waterproofing? What type of adhesive?
Jaz
Old 03-04-2011, 02:23 PM   #4
tjlacy
The floor is concrete, the walls hardieboard,there is a vapior barrier behind the hardie and the seams are sealed with redguard
Old 03-04-2011, 02:23 PM   #5
am using ultraflex thin set
Old 03-04-2011, 05:08 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So that's it? Just concrete? No tile, no shower pan liner, no nothing else, just concrete?
If this is the case you don't need to use a ledger board.
XXX
Old 03-05-2011, 11:50 AM   #7
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
This is a pic of my shower. I started with a ledger board for several reasons. First, my pan was not perfectly level (which is not uncommon). If your first row of tiles is not perfect, everything will be off.
Second, I wanted full tiles below the window, and with careful planning and measuring, I was able to do this.
The Following User Says Thank You to Blondesense For This Useful Post:
tjlacy (03-05-2011)
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 02:53 PM
Ledger Board Mounting Wildie Building & Construction 6 04-04-2009 10:02 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 09:16 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
