Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 11-28-2011, 03:51 AM   #1
Laying tile on top of tile (Flooring)
I want to know if I can lay ceramic tile on top of old thin, thin, think tile because the current tile has little to zero damage. Is this possible?
ed
Ed. B is offline   Reply With Quote
Old 11-28-2011, 07:35 AM   #2
Super Moderator
Ceramic can be set over existing ceramic using unmodified thinset mixed with liquid latex---
Kerabond and Keralastic by Mepei is a good example.
The existing ceramic must be perfect---Scuff the old tile with course sandpaper first--An angle grinder with 36 grit paper (two disks back to back) makes for a quick scuff.
Old 11-28-2011, 08:08 AM   #3
If you are trying to safe time with this I would recommend spending the extra time to remove the old tile.
Most ceramic tile does not have a exact thickness. This variation in thickness can cause big problems and crack your new tile
AirdrieHandyman is offline   Reply With Quote
Old 11-28-2011, 08:22 AM   #4
Super Moderator
Could you explain why the slight variations would cause the new tiles to crack?
I never heard of that problem.---Mike---
Old 11-28-2011, 08:26 AM   #5
The thickness of the old tiles may not be exact. This is something you may notice by feel but if you try to attach a new tile onto it this could cause a tile to not have full contact to the surface underneath. Then the tiles may crack. This is why subfloor prep is so important in tiling.
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 11:43 AM
Another Knucklehead Considers Laying Tile Over Vinyl Flooring tacklingherlist Flooring 14 08-27-2011 12:13 AM
Questions on tiling a floor abefroman Flooring 25 07-28-2010 11:18 PM
Laying diagonal tile on first floor - unsure of how to meet up the tile HRS1 Flooring 9 08-22-2009 04:50 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
