-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Laying tile on top of tile (Flooring) (http://www.diychatroom.com/f84/laying-tile-top-tile-flooring-124843/)
Ed. B 11-28-2011 02:51 AM
I want to know if I can lay ceramic tile on top of old thin, thin, think tile because the current tile has little to zero damage. Is this possible?
ed
oh'mike 11-28-2011 06:35 AM
Ceramic can be set over existing ceramic using unmodified thinset mixed with liquid latex---
Kerabond and Keralastic by Mepei is a good example.
The existing ceramic must be perfect---Scuff the old tile with course sandpaper first--An angle grinder with 36 grit paper (two disks back to back) makes for a quick scuff.
AirdrieHandyman 11-28-2011 07:08 AM
If you are trying to safe time with this I would recommend spending the extra time to remove the old tile.
Most ceramic tile does not have a exact thickness. This variation in thickness can cause big problems and crack your new tile
oh'mike 11-28-2011 07:22 AM
Could you explain why the slight variations would cause the new tiles to crack?
I never heard of that problem.---Mike---
AirdrieHandyman 11-28-2011 07:26 AM
The thickness of the old tiles may not be exact. This is something you may notice by feel but if you try to attach a new tile onto it this could cause a tile to not have full contact to the surface underneath. Then the tiles may crack. This is why subfloor prep is so important in tiling.
