Layers Of A Bathroom Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-11-2012, 01:24 PM   #1
Layers of a Bathroom Floor
Would you please confirm this to be the proper series / sequence of bathroom layers going from joist to tiled flooring:
- 3/4" plywood (construction-adhesive taped to joist)
- 1/2" plywood (type BC, staggered, screwed to 3/4" plywood: 4" perimeter, 6-8" field using 2.5" galvanized)
- mortar bed
- 1/2" sheetrock (screwed to plywood: 4" perimeter, 6-8" field using 2.5" galvanized)
- (electric floor heating, if applicable)
- mortar bed
- tile
Thank you.
Last edited by nixplix; 02-12-2012 at 10:21 AM. Reason: No intelligent, useful replies yet.
nixplix is offline   Reply With Quote
Old 02-11-2012, 10:12 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Something ain't right about this.
I'm no tile person and know this is wrong.
titanoman is offline   Reply With Quote
Old 02-11-2012, 10:27 PM   #3
Rewards Points: 14,300
It's not tape, it's adhesive in a tube. I'd suggest using 3/4" T & G Advantec subflooring instead
Use 1/2 Subfloor rated plywood. it will say right on the panels.
Use ceramic coated decking screws instead, there not going to rust off and almost never snap off or round off while installing.
- mortar bed
Sheetrock in any form is never used on a floor.
- mortar bed
- tile
Thanks.
Are you sure you do not want to hire this one out?
Tags
subfloor bathroom durock
Help with ceramic floor bathroom lornescot Flooring 0 11-19-2011 12:35 PM
Bathroom floor & shower waterproofing questions hotbread Tiling, ceramics, marble 0 01-24-2011 12:39 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Bathroom 'wet floor' - floor slope options Couch Plumbing 9 03-11-2008 04:42 PM
