Large Tile Install - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 06:29 PM   #1
large tile install
ive been reading a lot of posts on here the last month or so and figured i would post a question. i'm planning on installing some 22x22 porcelain tile in my kitchen. i have 2x10 joists, 16 OC, 11'4" span and 3/4 OSB tongue and groove. Because of height issues i dont want to add anything to the floor but ditra and tile. I plan to flatten the floor as much as i can before the ditra goes down and im using ditraset to set the tile and the lash system to prevent lippage as i have never worked with tile this large before. anything else i need to consider or be aware of?
Old 05-26-2011, 07:11 PM   #2
DIY staff
Rewards Points: 7,174
I checked the deflection chart and you are 618 which is good---With the Lash clips and that large of a tile I think a 1/2x 1/2 trowel is what you want---
I hope you have a bridge saw for those tiles ,it will make you job a lot easier---Mike---
Old 05-26-2011, 09:20 PM   #3
thanks for the reply. so other then having to lay those big tile i should be ok with everything else? ive been reading the post on here for a while and picked up on what i needed to do. lot of knoweledgable people on here. I was a plumber for 20 years then switched to trim carpentry. i used to be a jack of all trades and a master plumber. i dont have a bridge saw just a regular wet saw. im hoping the layout works out in my favor.
Installing Porcelain tile, complete guide? Total Sugar Flooring 5 03-07-2011 09:22 PM
Can I install ceramic tile onto an uneven and un-level concrete floor? Integraoligist General DIY Discussions 17 02-03-2011 08:43 PM
Adhesive for large ceramic tile over concerete slab GeauxCajuns82 Tiling, ceramics, marble 2 11-18-2010 05:13 PM
Can I install mesh back mosaic tile directly to primed drywall jenrao9991 Tiling, ceramics, marble 5 03-17-2009 06:08 PM
Large gap between granite splashboard & tile rlmink Remodeling 1 10-06-2008 04:22 PM
