Large Format Tile For Countertop - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-22-2014, 08:46 AM   #1
Rewards Points: 280
Large format tile for countertop
I had to give up on the granite prefab, my friends are too old and broken down to help. The one young friend I have has a hernia!
So now I am planning on using 18X18X1/2" granite tile for a 40 sq ft kitchen countertop. I have done some small tile projects for myself over the years, but really do not know anything about tile..
I have a 3/4" plywood base which I will attach tile backer board to and then tile.
I am reading with this tile I should use a 1/2" notched trowel for the thinset
Seeing as it is not going to be walked on or weight bearing could I use a smaller notched trowel?
My goal is to keep the thinset as thin as possible, without creating a problem. I will be doing an undermount sink and it seems like a thick bed of mortar would be an issue?
Are there any alternatives to thinset? JIm
jjrbus is offline   Reply With Quote
Old 05-22-2014, 09:02 AM   #2
Rewards Points: 14,312
I'd be rethinking the under mount sink idea and going with a drop in on this one.
Old 05-22-2014, 03:02 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Granite tile has a very smooth backside and does not require a 1/2" notched trowel, that would be insane.
A 3/16" notch would be fine if you comb the substrate all in one direction and then back butter the tile smooth.
XXX
Old 05-22-2014, 05:04 PM   #4
Rewards Points: 4,796
Since this is a countertop and you can easily get the surface (plywood) very flat, you can get by with thinner thinset.
I would use Ditra, not backerboard, for a kitchen countertop. This would also allow easier waterproofing.
But don't you want 24" tile? 18" is a pretty narrow countertop.
jeffnc is offline   Reply With Quote
Old 05-23-2014, 11:36 AM   #5
Rewards Points: 280
Thanks for the input. 18+6=24. 24" tile is hard to come by in this area, at a reasonable price anyway.
I will look into the ditra. JIm
Old 05-23-2014, 04:59 PM   #6
Hmmm, 6" strips - don't think I'd like that.
You could order online, you might find 24 x 24. This would be an improvment over 18 x 18
http://www.builddirect.com/Granite-T..._10085613.aspx
You could try this
http://www.builddirect.com/Prefab-Co...073_Ne_27.aspx
Old 05-23-2014, 08:56 PM   #7
Rewards Points: 280
I looked at Builders direct, They are not real forthcoming with info. But they appear to be glorified 12X12 tiles at a minimum of $25 sq ft. With a minimum purchase of $1250.
At $25 a foot I would rather spend some more and go for granite counters.
This seems a much better deal??
http://www.rockbottomtileandstone.co...ite-mini-slabs
Thanks JIm
Old 05-23-2014, 09:28 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You obviously haven't priced granite counter tops.
You won't be finding them for no twenty-five dollars per square foot.
XXX
Old 05-23-2014, 09:31 PM   #9
I'm not sure what you mean. I just tried to check out using one of the products on that first link I gave you. Shipping is very expensive, but the price with shipping was less than $6/sf and I was ordering 96 sf for $556 with shipping.
Old 05-23-2014, 09:32 PM   #10
Read what he wrote again....
Old 05-23-2014, 09:34 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What'd I miss?
XXX
Old 05-23-2014, 10:22 PM   #12
He said if the tile was going to cost him $25/sf, he'd rather go ahead and spend more and just get the granite countertops. He's looking to save significant money off the granite countertops, not just 40 or 50%.
Old 05-24-2014, 04:36 AM   #13
Rewards Points: 280
Sorry I did not look at the links. When shopping I found their tile kits to be way overpriced IMHO! I do not like any of the colors in their large format tiles, but they are a great deal. Thanks for pointing them out.
The way I read it they have a minimum purchase + shipping. I can buy what I need in a color I like for about the same money. But in an 18X18 tile.
I need about 40 sq ft of counter, I live in Ft Myers FL area where the counter top market is very competitive. I would guess I could get it done in the high teens?
I should just go buy some linoleum and chrome edging and be done with it!
Thanks for all the input always appreciated. Semper Fi JIm
Old 05-24-2014, 09:38 AM   #14
Rewards Points: 240
i saw a black granite tile countertop, 12" tiles. very little or no gap (i don't remember).
that was put in by someone i know to be a hack. and it looked pretty good for what it was.
i would want 24" tiles. but often you have to do what you can afford.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
jjrbus (05-24-2014)
Old 05-24-2014, 10:07 AM   #15
Well, all I can say is 24" x 18" tile is very usable even if you can't find 24" x 24" locally (obviously arrange the tile so it covers lengthwise from the wall to the front of the counter - no "horizontal" grout lines.) And <$6/sf including shipping sounds pretty darn acceptable to me. But whatever floats your boat....
The Following User Says Thank You to jeffnc For This Useful Post:
jjrbus (05-24-2014)
Boxed Tile Different than Sample on Floor greentrees Tiling, ceramics, marble 4 05-31-2012 07:03 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Help with Large tile set Alwysbsy Tiling, ceramics, marble 1 03-22-2011 11:20 AM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
