Large 18";tile Or Smaller 12" Tile For Bathroom - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 06:21 PM   #1
Large 18";tile or smaller 12" tile for bathroom
Hi, I have a small 5' by 6 ' bathroom floor which I'm going to re-tile. Is it better to use the larger 18"x18" tile or use the smaller 12"x12" tile?
lolsitmer is offline   Reply With Quote
Old 02-05-2012, 06:25 PM   #2
DIY staff
Rewards Points: 7,174
That is really a design choice---The 18x 18 tiles will give you a more modern open look--
The 12x12 a more traditional look
Which do you prefer?
Old 02-06-2012, 02:18 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Better in what way?
Have you done much tiling?
If not, you might go with the 12".
One would think that 18" tiles would be easier, after all, there will be less of them, and less grout, right?
The problem is lippage. Lippage is when the edge of one tile sticks up higher than the one next to it. The larger the tile, the more this becomes an issue if your tiling surface isn't perfectly flat. The larger the tile, the less forgiving they are.
Old 02-11-2012, 11:21 PM   #4
Rewards Points: 212
Originally Posted by Blondesense View Post
Better in what way?
Great advice!
bluebird5 is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Replacing large window for a smaller one wedge22 Building & Construction 5 08-29-2008 07:58 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
