Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 12-17-2012, 05:34 PM   #1
Laminate Flooring
I saw a small drop of water in one of the seams of my laminate flooring. Approximately a week later, several seams started to lift up. I tried to heat up the room in hopes to evaporate the water, but it hasn't worked out yet. Looking for some ideas.
svoll is offline   Reply With Quote
Old 12-17-2012, 07:14 PM   #2
Laminate Flooring
What room is this?
Is it a slab or below grade?
If it's a slab is there heat or plumbing run through the slab?
Old 12-17-2012, 07:32 PM   #3
Laminate Flooring
Originally Posted by joecaption
What room is this?
Basement floor. Basement never leaked. Just finished construction over summer. Had several parties and get togethers and then just recently noticed water coming up.
Old 12-17-2012, 07:34 PM   #4
Laminate Flooring
It is also below grade and there isn't any piping below concrete.
Old 12-17-2012, 07:36 PM   #5
Laminate Flooring
Most laminite not even beow grade rated.
Did you follow all the instrution on all the extra steps needed to install it below grade?
Old 12-17-2012, 07:50 PM   #6
Laminate Flooring
I believe so. My father-in-law has been doing construction for the last 30yrs. He was in charge, but now it is what it is. The biggest problem I'm having is I can't tell is something spilled or if is leaking in, because there is a small space between wood and plastic barrier every time you walk around the water keeps spreading. Don't know how to dry everything without pulling up the floor.
Old 12-17-2012, 07:57 PM   #7
Laminate Flooring
dehumidifier
Old 12-17-2012, 08:24 PM   #8
Laminate Flooring
dehumidifier
I have one set up for about 2 wks. You think I need to just wait and give it time?
Old 12-17-2012, 09:31 PM   #9
Laminate Flooring
If your thinking the floors going to flaten back down, most likly that's not going to happen.
Once laminite gets wet it's shot.
Also by now there may be mold growing under it.
Old 12-17-2012, 11:15 PM   #10
Pro Flooring Installer
rusty baker's Avatar
Laminate Flooring
Sounds like the moisture is coming thru the concrete, if so, it will only get worse with time.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 12-17-2012, 11:28 PM   #11
Laminate Flooring
Sounds like a perimeter drain system and sump pump may be called for.
http://www.usinspect.com/resources-f...erimeter-drain
Old 12-18-2012, 08:04 AM   #12
Laminate Flooring
Ok thank you. I guess I'll just have to pull up floor and clean up.
Old 12-19-2012, 05:09 PM   #13
Laminate Flooring
Thank you for all the advise. I just wanted to let you know I ripped open the sheet rock where it was the wettest and found a pipe with a small leak, which is where the water was coming from.
Old 12-19-2012, 06:04 PM   #14
Laminate Flooring
Thanks for taking the time to post again!
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
