Laminate Flooring - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-07-2011, 05:29 PM   #1
Laminate flooring
Trying to pit laminate flooring in a garage converted to a bedroom. The subfloor is raised plywood. My issue is, about a foot from the outer walls, the surface is raised about 1/2 inch or less. If I could double the padding, it would be perfectly level. I have read this is a huge no-no. With the areas being just slightly off, will this cause a huge problem. They will mostly be covered by furniture, and no one will be walking in these areas. I'd this is a problem, what could I do?
Jrice9 is offline   Reply With Quote
Old 10-07-2011, 08:57 PM   #2
A Little Of Everything
Rewards Points: 1,364
Unfortunately, this is probably going to be a problem. However, maybe a little clarification would be helpful.
When you say, "...is raised abut 1/2 inch or less..." what do you mean? Is one side of the floor 1/2" higher than the other one, or is there a lump, or what?
Why is that "raise" there?
DrHicks is offline   Reply With Quote
Old 10-07-2011, 09:33 PM   #3
Not sure why raise was originally there. Ww has to apply thin set in several areas to even out as much as possible prior to placing carpet. Basically this area of the floor is about 3mm higher than the rest of floor. If you place a level down, it is not that bad, just slightly uneven
Old 10-07-2011, 09:38 PM   #4
There's quite a bit of difference between 1/2 inch, and 3mm. If you're talking 3mm - which is close to 3/16ths of an inch, you might be fine, provided it's a very gradual rise. There is a little bit of "give" in hardwood laminate, but not much.
Old 10-12-2011, 12:44 AM   #5
raised spot on concrete
as long as the floor is flat, it doesn't have to be level. Laminate floor should stay down.If it's actually "raised" slightly by the wall, a self leveling underlayment might want to be used. Several are out there. Make sure it's not gypsum based. It has to be cement based. Ardex and Mapei are good ones.
Distributor Rep is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Laminate flooring and such for kitchen christineka Flooring 5 01-04-2011 08:08 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
