Kitchen Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-09-2013, 10:37 AM   #1
Mlwhite's Avatar
Rewards Points: 29
Kitchen floor
I currently have a wood kitchen floor. It is pretty bad shape and I would prefer tile. However, I've been told that I can't put tile in because I would never be able to get the dishwasher out if needed. Is there a way around this?
Thanks,
Michelle
Mlwhite is offline   Reply With Quote
Old 06-09-2013, 08:25 PM   #2
Rewards Points: 240
look at the bottom of the dish washer, look for the feet. are they adjusted out a lot ? or not
if the wood floor is in bad shape, take it out. how thick is the wood floor ?
Fix'n it is offline   Reply With Quote
Old 06-09-2013, 10:58 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 422
Michelle,
When you say the wood is in bad shape, I'm assuming you have a hardwood floor, is that right? If so, you can't leave that in place anyway, it needs to be removed.
If you'll tell us what you've got in detail, we can help. Start with the type and thickness of the subfloor, then what ever is over it.
Jaz
Old 06-10-2013, 06:54 AM   #4
Rewards Points: 4,796
Doesn't the wood extend under the dishwasher? If not, the dishwasher should have adjustable feet. If not, then worst case is you can install tile everywhere except under dishwasher.
jeffnc is offline   Reply With Quote
Old 06-10-2013, 09:50 AM   #5
Amateuralex's Avatar
Rewards Points: 270
You could have your floors refinished. Probably immensely less expensive than changing it out for tile, and it will avoid a ton of potential hassles like subfloor problems (and your dishwasher problem).
My dishwasher is also hopelessly locked into its spot. I guess the counter height was set up for the previous vinyl flooring? And dishwasher heights haven't changed since 1978? I guess I am hoping that when the dishwasher dies, I'll have enough cash to do the countertop replacements we want. Otherwise I'll have to figure something out!
Amateuralex is offline   Reply With Quote
Old 06-16-2013, 12:31 PM   #6
Mlwhite's Avatar
Rewards Points: 29
Sorry for the delay, here are pictures of the sub floor and floor. The wood floor does not extend all the way under the dishwasher however if memory serves correctly the front feet partially sat on the wood floor. Hope this is the info you are looking for to help me. Again thanks for any help!!
Michelle
[ATTACH]72767[/ATTACH
Old 06-16-2013, 01:18 PM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,790
Certainly.... Even if installing tile or wood, just put a maybe 3-4" "transition strip" piece of removable wood (rather than tile) in front of the dishwasher.
Stain it roughly the color of the tile, just put it down with 3 finishing screws. I grout right up to it.... and if I ever have to remove/repair the dishwasher, remove three screws, and just regrout it when replacing the dishwasher.
You'll never notice it if done neatly.
MTN REMODEL LLC is online now   Reply With Quote
Old 06-21-2013, 09:50 AM   #8
Mlwhite's Avatar
Rewards Points: 29
Has anyone seen or heard of using a Kerdi membrane for a kitchen look instead of cement board? I was at my friends house and they were doing this. Just curious how the tiles would hold up.
Michelle
Old 06-21-2013, 10:16 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 422
What do you mean by;
Did you by chance mean to write Ditra?
Jaz
Old 06-21-2013, 10:23 PM   #10
Framing Contractor
Rewards Points: 126
They do make a dishwasher that is about 1" shorter. Pricey though. I have mine imbedded in as well. If it dies, I can sawzall it out, or change my countertops. They are 18 years old anyway.
sixeightten is online now   Reply With Quote
Old 06-22-2013, 06:09 AM   #11
DIY staff
Rewards Points: 7,174
The hardwood must be removed before tile can be installed---hardwood moves a lot over the heating season and will cause early failure of a tile floor.
Before you go much further in your planning---tell us about the floor structure.
Type of floor joists? Size? spacing? length from foundation to center beam or other support.
kitchen floor advice Grumpy Flooring 4 03-21-2011 04:34 AM
linoleum floor for new kitchen evey Flooring 1 03-04-2011 04:43 PM
Sagging floor in kitchen...Advise please MGK01 Flooring 3 02-25-2011 12:34 PM
Rookie DIY'er: Kitchen Floor Project Gpike Flooring 2 02-25-2011 12:30 PM
