Kerdi - To Band Or Overlap? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 02:56 AM   #1
Kerdi - to band or overlap?
For those that have used Kerdi membrane in their shower/tub surrounds...
Is it easier to cut the Kerdi to fit the walls and then use Kerdi-band on the joints or is it easier to just cut the Kerdi sheets to create the 2" overlap with the original sheets?
e.g. How difficult is it to work a 2" portion of a large piece of Kerdi around a corner? Is it easier to manage just working with sheets on flat surfaces and then use Kerdi-band in the corners?
Thx,
Chris P.
chrispy35 is offline   Reply With Quote
Can I install Kerdi over primed drywall in a basement bathroom? Mechelle Tiling, ceramics, marble 13 04-22-2012 10:50 AM
Suntouch Heat Mat and Kerdi in Shower Quickdraw Kitchen & Bath Remodeling 0 03-15-2010 07:48 PM
kerdi fix drying under membrane hacksepe Building & Construction 1 09-30-2009 09:35 AM
Kerdi Basement Shower ldogg Flooring 7 09-13-2009 08:28 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
