Insulation And Kerdi Board - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 08:58 PM   #1
Insulation and kerdi board
Hi everyone, I'm about to start putting up kerdi board in my shower stall. I want to do the ceiling first but I have blown insulation being held up by some poly up there (2nd floor shower). Because k-board has/is a vapour barrier how would you suggest I address this? Remove poly and replace with some batts ten kerdi board? Or remove poly and insulation entirely?
Snaik69 is offline   Reply With Quote
Old 03-23-2013, 11:43 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 288
Hi,
I think you should be fine as is cuz the other side of the barrier is not a cold wall. But vapor barriers are very confusing and recommendations vary depending on the area and weather conditions. Check with your local building department.
I guess the insulation is there to soften noises?
Jaz
Kerdi Membrane Question/ Vapor barrier wrea398 Building & Construction 2 09-04-2010 09:40 PM
Bathroom Renovation ranapratab Remodeling 9 10-02-2009 12:05 PM
