Installing Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 04:49 PM   #1
installing tile
how many times can I put down tile over tile?
It already has two layers.
yolalford is offline   Reply With Quote
Old 11-18-2010, 03:46 PM   #2
Rewards Points: 45
I'm not an expert on this but I think that 2 layers of tile would be the maximum and if you want to install new tiles you'll have to remove everything down to the sub floor. That's what I would do at least. IMO removing old tile is much easier than removing linoleum (which I did in my kitchen/nook and took 2 weeks to finish).
Matt
Lafayette, LA
GeauxCajuns82 is offline   Reply With Quote
Old 11-18-2010, 06:40 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What are your structural load ratings for your home? That's where you should start. You may already be asking for structural problems.
XXX
Basement Floor Variance Allowance When Installing Ceramic Tile june Introductions 0 10-26-2010 10:09 AM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Would installing ceramic tile in a crawlspace work well? Red Squirrel Tiling, ceramics, marble 11 07-22-2009 03:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
