Installing New Stone Tile In My Bathroom - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-21-2013, 09:11 PM   #16
Axhammer's Avatar
I was able to maintain tile height wrapping around the shower jamb.
Pure-Pontiac
"See ya at the drags"
Moyock NC
Axhammer is offline   Reply With Quote
Old 08-21-2013, 09:16 PM   #17
Axhammer's Avatar
Tomorrow I can swap sides with the plywood, and do the other side, and start working the niches, fun stuff!
Pure-Pontiac
Moyock NC
Old 08-21-2013, 09:25 PM   #18
Pro
JetSwet's Avatar
Rewards Points: 502
Originally Posted by Axhammer
I cut a strip of plywood and screwed it to the shower entrance jamb to use as a guide, and installed the tiles, trying to maintain a straight and neat edge.
What is that thing next to the drain and wall?
Looks like you still have to make your pre-slope, what are your plans for that? Or is that done
JetSwet is offline   Reply With Quote
Old 08-21-2013, 09:35 PM   #19
Axhammer's Avatar
This link covers the pre-slope.
tile shower replacement with new tile
That thing in the picture is a plastic tub full of screws and spacers, next to a vacuum cleaner. It's a small bathroom, I keep moving everything around depending on what area I am working on.
Pure-Pontiac
Moyock NC
Old 08-21-2013, 09:37 PM   #20
Pro
JetSwet's Avatar
Rewards Points: 502
What are you doing about the wood in shower entry jam?.. You tiled around it like its staying there.... Needs to be covered, waterproofed then tiled and will then will through your tiled edges way off....
Old 08-21-2013, 09:52 PM   #21
Pro
JetSwet's Avatar
Rewards Points: 502
What's on your shower floor now.. Looks like cement board.
Old 08-21-2013, 10:21 PM   #22
Axhammer's Avatar
http://www.diychatroom.com/f15/tile-...w-tile-183902/
If you click on this link, it will answer your question.
Pure-Pontiac
Moyock NC
Old 08-22-2013, 11:32 AM   #23
Pro
JetSwet's Avatar
Rewards Points: 502
I already know the answer.... But do you know the answer... I just read a lot of Mike telling you to read the link and your confusion results in going back to read his link. Why do you want to put heating in the shower floor?
Anyway make sure you roof felt the bottom then use wire mesh for deck mud, deck mud doesn't stick to wood or concrete. If you want heating membrane then this becomes 2 part deckmud or if you forgo the heating then build your deck mud up to hight then kerdi or redguard top.
Old 08-22-2013, 01:47 PM   #24
Axhammer's Avatar
The shower pan has been finished for over a week or more.
I put electric heat under the bathroom floor.
I'm in the tiling stage now, do you have any helpful tiling suggestions?
Pure-Pontiac
Moyock NC
Old 08-22-2013, 09:42 PM   #25
Axhammer's Avatar
I put my plywood guide on the other side and tiled as straight and even as I could make it.
Pure-Pontiac
Moyock NC
Old 08-22-2013, 09:45 PM   #26
Axhammer's Avatar
The first side came out pretty good, I'm happy with it.
Pure-Pontiac
Moyock NC
Old 08-22-2013, 09:47 PM   #27
Axhammer's Avatar
I worked on the niches a little too.
Pure-Pontiac
Moyock NC
Old 08-24-2013, 10:28 PM   #28
Axhammer's Avatar
Making progress slowly.
Pure-Pontiac
Moyock NC
Old 08-24-2013, 10:32 PM   #29
Axhammer's Avatar
A little at a time, it's getting there.
Pure-Pontiac
Moyock NC
Old 09-01-2013, 09:43 PM   #30
Axhammer's Avatar
I finished installing all the tile in the shower, and applied a coat of red guard on the shower pan. Tomorrow I plan on installing the 2" tile in the shower pan, and some other tiles in the bathroom corners. My countertop and sink should be ready next week. I'll cut and install the remaining course just above the pan after everything is cured.
Pure-Pontiac
Moyock NC
Installing Stone Veneer Over Tile (see pic) bpdavis0 Tiling, ceramics, marble 10 05-29-2012 08:06 AM
Heavy natural stone wall tile: mastic or thinset? Is drywall adequate? Minich Remodeling 8 02-01-2012 08:27 AM
Installing floor tile but don't want grout gap to turn black overtime gatorade Flooring 4 02-06-2011 11:13 PM
Installing towel hanger shelf through bathroom tile and drywall zeramuas Kitchen & Bath Remodeling 3 01-14-2011 07:01 AM
Installing Hardwood Floor butting up to tile Macker Flooring 3 01-02-2011 03:21 PM
