Installing Large Wall Tiles - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-22-2012, 10:21 AM   #1
Rewards Points: 79
Installing large wall tiles
Iím remodeling our downstairs full bath, and this is my first time working with large wall tiles, 13 by 19.5.
I plan to install them one row at a time, especially the bottom row to make sure nothing sags and becomes un-level. Iíll use a laser to insure level!
My Questions: What is the best adhesive to use on the wall for larger tiles? Should I use a ľ inch trowel, the same as if I were installing them on the floor?
The Geek
papageek is offline   Reply With Quote
Old 06-22-2012, 05:34 PM   #2
Rewards Points: 512
http://www.flextile.net/products/CIS...esives-90.html
this is what i use for most of my tile jobs.
princelake is offline   Reply With Quote
Old 06-22-2012, 08:07 PM   #3
DIY staff
Rewards Points: 7,174
Yikes---Wrong stuff---Use a modified thinset---powdered,mixed with water---never a mastic in a wet area--it will desolve when water gets to it.
And never under larger tiles--mastic doesn't 'cure' it dries like paint.
Under a large tile it could take weeks,months or longer to dry.
Use a quality modified thinset--start tiling from the second course--add a wood ledger board to hold up the weight---also use a leveling system to keep the tiles flat to each other--
Tuscan makes one and Lash by QEP is another---
A deep trowel will be needed--1/2" x1/2"-----Never bucket mixed stuff in a shower--
Old 06-22-2012, 09:27 PM   #4
Rewards Points: 512
lots of flooring guys here use flextile, i've used it in my own house. i did my bathroom 2 years ago. 2 hours after i finished putting down the tile on my floor i noticed a chip on one of the last tiles i put in and i had to smash it to get it off the floor cause it was already setup. i only use thinset on concrete.
Old 06-23-2012, 04:18 AM   #5
DIY staff
I stand by what I said---I've seen to many failures with premixed mastics--TCNA backs up my personal experience in their hand book.
Thinset is a sure thing in wet areas--and far less expensive than the bucket mixes---
Best to use the safest --use thinset---Mike---
Old 06-24-2012, 03:35 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Mike is right on this thread, no tile glue by wet era's my old boss one time told me to use it in aprt bathroom I used thinset but had the bucket there for show.
JetSwet is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Installing copper gutter to replace some concrete tiles whattodo Roofing/Siding 2 07-28-2009 07:28 AM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Replacing A Few Tiles On Shower Wall EDENO Remodeling 1 12-11-2006 11:25 AM
