Installing Hardy Backer Board For Floor Tile Installation - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 11:16 AM   #1
installing hardy backer board for floor tile installation
Hi, I am attempting to install hardy backer board over a 3/4" sub floor. My question is should the backer board be installed with the grain of the plywood or against the grain of the plywood? Or does it really make a difference either way? Just an FYI the floor joists are 12" on center. Any Information will be helpful.
popeyemike is offline   Reply With Quote
Old 03-25-2012, 12:42 PM   #2
Rewards Points: 2,516
Don't think it matters but make sure none on the edges of the backerboard fall on the joints/edges of the subfloor.
Are you going to be laying the backerboard in a bed of mortar AND screwing it down? Or are you only going to screw it down?
hammerlane is offline   Reply With Quote
Old 03-25-2012, 04:29 PM   #3
Mortar and screws.
Old 03-25-2012, 05:55 PM   #4
Originally Posted by popeyemike View Post
Mortar and screws.
Old 03-25-2012, 07:05 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 412
Trick question there. You do not have a choice.
Jaz
Old 03-26-2012, 10:57 AM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Some DIYers don't know that there is not a choice.
Doesn't matter which direction the cement board goes.
The other question would be what kind of screws are being used for the cement board?
JetSwet is offline   Reply With Quote
Old 03-26-2012, 11:52 AM   #7
Tileguy
JazMan's Avatar
Rewards Points: 412
What bothers me is how many so called pros that don't know how to install CBU's correctly.
Jaz
Old 03-26-2012, 01:03 PM   #8
Jaz
Yes it was a trick question. Unless of course you want your grout to crack.
Old 03-26-2012, 01:06 PM   #9
Pro
JetSwet's Avatar
Rewards Points: 502
Jaz
I like to use the term pro loosely as a cynical reference to some one who knows how to do it as pose to some one who does not know how to do it.
Old 03-26-2012, 01:11 PM   #10
We needed about 450 sq feet of floor tile laid. Had a local guy come in for quote. Said he used hardibacker for the underlayment and that he screws it down. no need to set the hardibacker in mortar.
At that point I knew that hardibacker says to install in mortar and screw down. I figured either the guy was not knowledgeable or was trying to cut corners. Needless to say he did not get the job.
Old 03-28-2012, 06:51 PM   #11
Tileguy
JazMan's Avatar
Rewards Points: 412
I used to be surprised how many people who charge to install tile but don't know the right way to do things.
Any new info or thoughts?
Jaz
Old 03-31-2012, 12:40 PM   #12
Anyone know thre best type of mastic for installing cement baker board to a 3/4" plywood sub floor?
Old 03-31-2012, 03:02 PM   #13
Tileguy
JazMan's Avatar
Rewards Points: 412
Mike,
You should use thinset mortar, not mastic. Thinset is much better, you'll also need it for the tiles, and it's cheap too. Thinset comes in powder form in a bag, do not use anything that is pre-mixed.
What brand of backer board are you using? What kind of tiles are you installing?
Jaz
Backer Board Around Tub Deteriorated. devnull88 Plumbing 2 05-18-2011 03:56 PM
cement backer board or not? Jroberts8192 Tiling, ceramics, marble 4 04-18-2011 08:27 PM
Green board, blue board, backer board??? ddougee Remodeling 5 03-21-2011 09:58 AM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
