Incorporating Stair Spindles When Tiling With Porcelaine - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-03-2013, 05:35 AM   #1
Renovation Junkie
Incorporating stair spindles when tiling with porcelaine
Whats the best way to incorporate baluster spindles into porcelaine tile? I'm thinking of removing the spindles from the baluster, cutting them to the new lenght and pinning them into per drilled holes in the tile. Thoughts?
Thanks, Yves
Rass61 is offline   Reply With Quote
Old 10-03-2013, 05:52 AM   #2
DIY staff
Rewards Points: 7,174
Is it safe to assume you are tiling a stair case?
If this is a balcony---add a wood stair nosing--I don't like the idea of holes into the tile so close to the edge---this is a fragile area---
More info,Please.---Mike----
Old 10-03-2013, 08:11 AM   #3
Renovation Junkie
Mike,
Its not a staircase. This is a short railing (60") with approximately 6 spindles, a newel post and 1/2 post butted against the wall on the main floor along a floor opening with 2 steps down leading to a mid level acces landing to my garage access.
Old 10-03-2013, 09:47 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
60 inches with 6 spindles will not pass code, insurance will not pay if out of code.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (10-03-2013)
Old 10-03-2013, 10:35 PM   #5
Renovation Junkie
Ok It's more like 5 spindles @ 30". But that's not the issue.
Old 10-03-2013, 11:03 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
As to the issue, I agree with Mike, about the weakness drilled that close to the edge. Another issue will be the spindles will become loose as there is little to glue to on the bottom, also tile and wood expand at different rates.
Jim
Old 10-09-2013, 12:25 PM   #7
Renovation Junkie
Thanks ! I've decided to attach the spindles to a shoe moullding and tile around the shoe instead
Stair tiling question... avro1 Flooring 1 03-27-2013 11:01 AM
Need to tighten spindles on stair rails. crescere Building & Construction 21 02-02-2013 06:21 PM
Painting the spindles of a stair case mimijack Painting 9 09-16-2012 05:17 AM
Stair Tiling Problem wartman49 Flooring 5 05-28-2011 03:16 PM
stair spindles jimmyboy Carpentry 4 12-15-2007 03:17 PM
