Imer Wet Saw Setup - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-05-2010, 08:22 PM   #1
Imer wet saw setup
Hello,
We just rented the Imer 250v. I have never used at wet saw, and the manual is very vague. Do I just lay the water pump in the water tray?
Thanks.
Pernille
ThomasPernille is offline   Reply With Quote
Old 03-06-2010, 04:27 AM   #2
Rewards Points: 1,016
Originally Posted by ThomasPernille View Post
Hello,
Thanks.
Pernille
I have not used that perticular saw, but others I have used - yes, the pump lays in the tray with the hose of course running up to the blade. Water showers over the blade and cut area and falls back into the tray. Watch the sludge as the water gets dirtied as it can clog the input screen to the pump.
Here's the manual - but agreed, it does not show the pump well.
http://www.imerusa.com/pdf/manuals/Combi250v2.pdf
Old 03-06-2010, 07:03 AM   #3
DIY staff
Rewards Points: 7,174
I'm not familiar with that saw either--I suggest you spend a couple of minutes and check the tool with a square --rental equipment (and anything portable) should be checked before you trust it to make a proper cut.---Mike--
Old 03-07-2010, 07:10 AM   #4
I have one, the pump is set under the tray in it's own bracket.
R&D Tile is offline   Reply With Quote
Tags
wet saw
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
New House Structured Wiring Setup for CATV gregsenne Electrical 13 02-19-2009 08:00 PM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 12:08 PM
Does anyone have a picture of a pex shower setup? twilightcall Plumbing 3 06-17-2008 06:25 AM
home theater setup cannouu Electrical 5 04-09-2008 06:01 AM
