How To Tile A Corner Where 3 Edges Meet - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 09:20 PM   #1
How to tile a corner where 3 edges meet
I have a question on tiling a corner. I am tiling my shower with 2x4 stone tiles. On some of the edges, I will be using corner tiles (the "L" shaped pieces that wrap around 2 sides.
In one area, I have a privacy wall between the inside of the shower and the toilet on the outside. There are 3 edges that meet: The horizontal running the length/top of the privacy wall, the vertical that runs down the front/face of the privacy wall, and the small horizontal wall that is perpendicular to the first two lines (think of the corner of a box).
My question is how do you tile the actual corner? If I run the top corner piece to the front, when you butt the two pieces together, you are always left with a gap. Do you fill that in with a small piece of tile? Cut off one of the sides of the L and notch it? See the picture:
JP's Dad is offline   Reply With Quote
Old 08-06-2012, 09:36 PM   #2
i would miter the front pieces and butt the one on the side.
but i am looking at it from a carpenter's point of view.
Old 08-07-2012, 06:18 AM   #3
DIY staff
Rewards Points: 7,174
Yep--Miter---If you are geometrically challenged----buy a bit of wood corner cap to practice with--
Old 04-01-2013, 05:44 PM   #4
FYI - the miter worked great! Thanks for the tip!
The Following User Says Thank You to JP's Dad For This Useful Post:
oh'mike (04-01-2013)
Old 04-01-2013, 08:42 PM   #5
Rewards Points: 240
an update !
looks GREAT ! how about pics of the rest
Fix'n it is offline   Reply With Quote
Old 04-01-2013, 08:53 PM   #6
Here it is:
Fix'n it (04-01-2013)
Old 04-01-2013, 09:37 PM   #7
DIY staff
That's a very comfortable looking shower---high class yet unpretentious---
Good design.--Mike-----
Old 04-01-2013, 09:51 PM   #8
Rewards Points: 240
yeah, looks GREAT. though, it looks like you need more shelves. those are easy to add.
what did you use for the curb ?
and behind the tile ?
what did the glass cost ya ?
Old 04-01-2013, 11:14 PM   #9
Nah, the shelves are bigger than they look. 12x12. Don't know why I took the picture with the stuff on the floor, but generally all is on the shelves. The ledge on the stub wall is actually about 4 inches wide on the inside and stuff can go there if needed. I wanted to keep it clean and un-cluttered as much as possible (I originally was going to put in a little corner seat also).
Curb is dry packed along with the base. On the walls, I used 1/2" Hardibacker then sealed with RedGuard. A little expensive, but I think it does a better job than felt paper. At least it does for my piece of mind. Then thinset and tile.
Glass wasn't too bad - $1200 dollars including hinges, track and handle. It was the only thing that I let someone else do, and well worth it. It's 3/8". Stub wall is 2x6's, stiffened with 1/2" plywood glued and nailed, then hardibacker on that. I also put extra blocking in the walls were the track is and obviously in the hinge. A tornado could hit that shower and it probably wouldn't move...
The Following 2 Users Say Thank You to JP's Dad For This Useful Post:
Fix'n it (04-02-2013), oh'mike (04-02-2013)
Old 04-02-2013, 09:55 AM   #10
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Very nice!
Old 04-02-2013, 08:09 PM   #11
Rewards Points: 240
sounds like you did a good job.
Wrap or Mirror Inside Corner Tile? Dsaj Kitchen & Bath Remodeling 0 06-06-2012 10:52 AM
routering corner edges on square columns mazac66 Carpentry 1 05-26-2011 07:42 AM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
Corner Metal Pieces (brace) for outside cordners Needed Before Tile jwhiteuwc General DIY Discussions 1 02-02-2009 11:57 PM
How to mud three wall/ceiling meet corner? KUIPORNG Remodeling 6 03-24-2007 12:51 AM
